Go to Post FIRST doesn't just prepare you for engineering, it prepares you for life - sciguy125 [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Perry Street Auto
ADVERTISEMENT
Unread 04-08-2003, 08:28 AM
odin892 odin892 is offline
#0892 (team ASCII: All Students Challenging Intellect and Ingenuity)
odin892 is an unknown quantity at this point
gyro code
we used a gyro to balance our arms but the gyro would return to center after about a second or two so we made a pendulum.
here is our code before we took it out. you may need to tweak some variables.
If p3_sw_top = 1 then
If p3_y > 127 then
If balancing_motor_limit_forward = 0 then balancing_motor = p3_y
else
if p3_y < 127 then
if balancing_motor_limit_reverse = 0 then balancing_motor = p3_y
endif
endif
else
If state = 0 then
balancing_motor = 183
If balancing_motor_limit_forward = 1 then balancing_motor = 127
If gyro => 180 then state = 1
else
If state = 1 then
balancing_motor = 63
If balancing_motor_limit_reverse = 1 then balancing_motor = 127
counter = counter + 1
If counter => 30 then
state = 2
endif
else
If state = 2 then balancing_motor = 127
endif
endif
endif
Unread 04-08-2003, 09:47 AM
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
Are you asking a question, or offering your code for others to use?
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 04-08-2003, 01:50 PM
i was offering code to other to use. it was supposed to be a reply but i clicked the wrong button and didn't realize.
What is your most prefered programming language? Hailfire Programming 156 01-19-2005 08:42 PM
Autonomous code PBoss Programming 7 01-14-2003 02:29 PM
Does your team use the Default code. Jeff McCune General Forum 2 01-09-2003 01:46 PM
Gyro Chip Code archiver 2001 4 06-23-2002 11:57 PM
[white paper] Auto-Balance Gyro Code Brandon Martus Technical Discussion 3 06-21-2001 09:36 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
