bad battery charger clips
has anybody else noticed that the clips that come with the chargers keep getting worse?
the ones last year were too wide and would touch while on the battery. ours have sparked so many times that the tips are burned away! people ended up putting paper in-between the clips, but that was annoying. this year they were even worse, they were so wide that they bearly fit in the plug and they were curved so they would not always touch the metal. why can't they just give us good clips and make everyone happy? |
FIRST doesn't have control over what kind of clips the chargers come with. They should let us modify them though (and give us better battery plugs.)
one thing our team did was rig up connectors with one of those battery plugs attatched to wires which we attatched the clips to...it worked better than tryin to get a good connection through the charger clips
I have advised my teams for years to do the same thing Mimi's team does. We cut off the clips and put on one of the Anderson Connectors. Not only is it much easier to connect the battery to the charger, you never have to worry about the battery leads touching accidentally. From experience, it is best to solder the leads of the charger to the leads from the Anderson connector, and then cover over with heat shrink. You will need at least a 60W soldering iron to do this.
Steve |
. We changed all of our battery connectors over on the Thursday when we got to Pittsburgh....you know the regional where the robot didn't make it till Friday ![]() |
actually i did a similar thing to mimi's idea in the pits during the J&J regional. i clipped the charger clips onto a battery cable and wrapped them with electrical tape. then i wrapped the two covered clips together with more electrical tape. we did not have any more plugs available, though, so the charger from last year is still the same.
My recommendation is removing the clips and substituting whatever connector you use for the battery. It is what we have done for many years. If nothing else, it prevents the clips from touching while the charger is on. It gives you a good, solid, low resistance contact that will not be bumped off accidentally and it is able to be used without removing the battery from the robot. I have seen many teams using the clips (alligator clips, gators, spring clips, crocks, whatever you call them.) and even though they work, they tear up the surface of the connector. Eventually this scratching increases the series resistance of the contact causing heating and failure.
We dont use that charger anymore.Steve is right about soldering the leads with a 60W soldering iron. Soldering 6 gauge wire to anything can be difficult. Make sure u get a good strong joint he first time and strain relieve it. The charger will get banged around during transport to competitions, and a broken joint can be a big problem. Once during a demo at the Riverfront Arts Center on the Waterfront, the leads on our only charger broke. I had to re-solder it with the 25W iron in my travel kit. I had to hold the iron to the wire for over 15 min to heat just to get the sold to melt on the 6 gauge wire. All I had for a work space was a Frisbee to catch the solder drops before they ruined the nice carpet (which I danced on a few weeks later during my Senior Prom at the Arts Center ). So do the job right the first time to avoid problems like that.Last edited by The Lucas : 04-19-2003 at 05:46 PM. |
| Battery Chargers | Neal Probert | Electrical | 46 | 02-16-2003 09:31 PM |
| Off-topic battery stuff. | FotoPlasma | Electrical | 4 | 01-06-2003 11:19 AM |
| battery charger | archiver | 2001 | 3 | 06-23-2002 10:20 PM |
| Exide Battery Charger | jeffreym | Electrical | 2 | 03-25-2002 02:06 PM |
| Voltage Range of Analog Inputs | Ulibrium | Electrical | 21 | 02-15-2002 01:11 PM |
