Go to Post FIRST will continue searching for rules and procedures to keep us from hurting ourselves. However, none of this will substitute for judicious application of common sense. - Richard Wallace [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ProCare Services
ADVERTISEMENT
Thread Tools Rating: Thread Rating: 2 votes, 3.50 average. Display Modes
Unread 01-26-2002, 11:30 PM
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
Inventor Assemblies?
Okay, I'm trying to model the frame of our robot in inventor. We are using 30x30 IPS extrusion, so I'm using the 30x30 drawing from Ed Spark's library.
I "Add Component" to my assembly four times, 3030.ips, one for each side of my rectangle (29inx35in). Here is the problem: When I extend one of the pieces (with edit: extrude) the other three are extended too! I can disable "Extrusion 2," but then all four pieces are the starting length!
I *can't* figure out how to get different lengths in there! I had some one tell me to just make seperate parts (.ips) of the right length. This seems really really inefficent to me. There has to be a Better Way! Does anyone know of it?
Unread 01-26-2002, 11:38 PM
kiracofe8 kiracofe8 is offline
#1317 (Digital Fusion)
kiracofe8 will become famous soon enough
Off the top of my head, I think that there should be a "Save As" or maybe "Save Copy As" function under the file menu. If you need the same cross section to be four different lengths, save it as four different filenames. That way, modification to one component does not affect the others...
/* Daniel */
Unread 01-27-2002, 09:41 AM
Unsung FIRST Hero
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #0034 (The Rockets)
Rookie Year: 1996
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Inventor Help
Jon,
Each unique component must have it's own part file. So as Daniel suggested, use "Save Copy As" to create these seperate part files.
If two or more components is your assembly are identical, then use copy and paste to place them in your assembly (or just drop multiple copies when you place the component). As you experienced, parts that are copies of a single part file will ALL change when the part file is changed.
Ed Sparks
The Rockets
FirstCadLibrary
Unread 01-27-2002, 02:35 PM
Bitter FIRST Cynic
Hrmm... that isn't terribly intuitive... but I guess it *does* make sense. Does Inventor support assemblies of assemblies? I guess that's what parts are for? It's going to take a little while to get used to this madness! Thanks for the help.
Unread 01-27-2002, 02:39 PM
Yes, assemblies of assemblies are allowed (and I would encourage you to use them. You can save yourself a lot of time this way).
/* Daniel */
Unsung FIRST Hero
Rookie Year: 1996
Thumbs up Yep !
You can have assemblies of assemblies ....
Ed Sparks
The Rockets
FirstCadLibrary
Unread 01-27-2002, 02:42 PM
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
Jon, yea you can insert assembiles into an assembly.
My chasis assembly had 4 assemblies and something like 42 parts in it.
Assembiles can get big FAST, I recomend if your making something large and complicated break it into small groups and then assemble those later. Rather than put it all together at once.
Unread 01-27-2002, 02:55 PM
Bitter FIRST Cynic
Ah! Okay. This sounds much better than I was thinking. So a chasis could be an assembly, and an arm could be an assembly, and good things like that. That makes more sense.
Unread 01-27-2002, 03:05 PM
AWiser's Avatar
AWiser AWiser is offline
AWiser is an unknown quantity at this point
Send a message via AIM to AWiser Send a message via Yahoo to AWiser
80/20 program
80/20 has an "AutoQuoter" program that is supposed to have all of their extruded aluminum products in it for designing. The only problem is that they say it needs AutoCAD, so I'm not sure if it will work with Inventor.
"Understanding AutoQuoter:"
http://www.8020.net/peace/autoquoter.asp
"Using AutoQuoter:"
http://www.8020.net/peace/usingaq.asp
Good Luck!
~Alex Wiser~ <Team #846 (Lynbrook)>
There are three kinds of people in the world:
Those who can count...
and those who can't
Unread 01-27-2002, 04:26 PM
AWiser's Avatar
IPS too...
Also, IPS has a program called "ProfileCAD" that apparently does the same thing. Unfortunately, they also say that it needs AutoCAD, so I'm not sure if this will work on Inventor either.
It's under the "Downloads" section at:
http://www.industrialprofile.com/
and those who can't
Unread 01-27-2002, 05:52 PM
AdamT's Avatar
AdamT AdamT is offline
#0401
Rookie Year: 2000
AdamT is on a distinguished road
You can import Autocad drawings into Inventor....
The problem is the 3d models of them aren't quite right.
~Adam
Unread 01-27-2002, 08:31 PM
Unsung FIRST Hero
Rookie Year: 1996
Exclamation Autocad -> Inventor
Autocad 3D Models are best translated by way of ACIS files.
Export the model form Autocad using FILE, EXPORT, and select ACIS(.sat).
Then open the ACIS(.sat) file in directly in Inventor.
You can then do a FILE, SAVE COPY AS, to save the file as an inventor part, inventor assembly, STEP file, IGES file .....
Ed Sparks
The Rockets
FirstCadLibrary
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
