Go to Post I had told my new team this joke: "They procrastinate so much, no wonder they're the Heroes of Tomorrow!", but I guess the joke doesn't have any truth in it anymore. They were really on their game this year! - JABot67 [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 01-27-2002, 01:09 AM
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
more help with Inventor
I am trying to create a solid cylinder whose faces are at an angle (so that it looks like a parallelagram instead of a rectangle when viewed from the side), but everything i've tried hasn't worked. Is this really hard to do, or am I missing something here? Thanks a lot in advance.
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 01-27-2002, 09:16 AM
Jan Olligs's Avatar
Jan Olligs Jan Olligs is offline
#0448 (Crandroids)
Jan Olligs is on a distinguished road
Re: more help with Inventor
Try the following: Draw a rectangle and attach two rectangles to its sides, then revolve everything about the common axis. Then, select "Share Sketch" and on the common sketch, use the mirror on evrything about your axis of revolution. Then, draw two triangles, one from the top left corner, then down to the last point that snaps, then right to the first point that snaps and back to your start corner. Do the same thing with the other side. Finish your sketch and select the extrude tool. Choose "extrude from existing parts" and "to both sides" (both are just icons). Select "All" in the menu. Then click extrude. You have a cylinder with a parallelogram as cross section.
I tried to attache an Autodesk Inventor Drawing file, but it seems as if the upload doesn't work.
Good luck!
I have great faith in fools - my friends call it self-confidence. --- Edgar Allen Poe
Unread 01-27-2002, 06:32 PM
ahecht's Avatar
'Luzer'
AKA: Zan
Thanks, that did the trick. However, now I have a new problem. I downloaded the INV file for the Bosch 30x30 gusset from the First CAD Library, but when I open it in Inventor, it thinks it is only 1.102mm wide. I’ve tried importing from the other formats, and specifying different default units, but it always comes out tiny.
Zan Hecht
Unread 01-27-2002, 08:21 PM
Jan Olligs's Avatar
#0448 (Crandroids)
Import of parts into Inventor
I don't have a response to that, but I tried it myself with different formats and you are right. I thought, though, that you already had a similar problem with a different part (Thread) and that your question was answered there. Can't you apply the solution of this problem to your current one?
Unread 01-27-2002, 08:35 PM
Unsung FIRST Hero
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #0034 (The Rockets)
Rookie Year: 1996
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Question I'll look into it .....
I'll look into it.
Could be that I exported the file using the wrong units of measure. Is the problem unique to this part? Have you been able to use other parts with success?
Ed Sparks
The Rockets
FirstCadLibrary
Unread 01-27-2002, 08:53 PM
Jan Olligs's Avatar
#0448 (Crandroids)
Successful use of parts
The only part I have used from the CAD library so far is the bushing with 1/2'' length, 3/8'' OD, 1/4'' ID. It worked out perfectly and I haven't had any conversion problems with that part. To use it, I imported the file "bushing-fbb-4-8.stp" into Inventor.
Unread 01-28-2002, 03:53 AM
ahecht's Avatar
'Luzer'
AKA: Zan
The problem from the other thread was solved by downloading the INV file, but this part is too tiny even with the INV version. Specifying what units to use doesn't help at all.
Zan Hecht
Unread 01-28-2002, 10:53 AM
Unsung FIRST Hero
Rookie Year: 1996
Thumbs down My Bad ........
I found the problem .... My bad ....
I made a mistake when I translated the part from Autocad.
I'll upload the correction tonight and put an "updated icon next to the part" (Can't upload from work).
Ed Sparks
The Rockets
FirstCadLibrary
Unread 01-28-2002, 09:32 PM
Unsung FIRST Hero
Rookie Year: 1996
Exclamation 30mm Gusset Model is Fixed....
All Fixed.
Sorry guys ....
Ed Sparks
The Rockets
FirstCadLibrary
Revisit: No. of Inventor Licenses - Great FREE alternative! Stu Bloom Inventor 1 10-15-2003 12:20 AM
Cybersonics 2003 Autodesk Inventor Submission petek Inventor 6 03-07-2003 11:11 AM
Autodesk Inventor Award 2002 Digo Inventor 1 03-24-2002 11:07 AM
Inventor and Virtual Kit of Parts Torchin Inventor 1 01-09-2002 08:59 AM
AutoCAD, Inventor, or Other D.J. Fluck General Forum 23 12-31-2001 07:59 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
