Go to Post It's all about bragging rights, awards, and pushing the envelope, not necessarily winning or practicality. - ahecht [more]
Go Back   Chief Delphi > Other > Unsung FIRST Heroes
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 09-15-2003, 12:00 AM
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
UFH: Rob Bayer
Thread created automatically to discuss UFH Honoree: Rob Bayer.
Unread 09-15-2003, 12:01 AM
Unsung FIRST Hero
Amanda Morrison Amanda Morrison is offline
Aut viam inveniam aut faciam.
Amanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond reputeAmanda Morrison has a reputation beyond repute
Congratulations to Rob Bayer for being our fourth Unsung FIRST Hero.
Thank you for all that you do for the FIRST community - it has not gone unnoticed.
Unread 09-15-2003, 12:25 AM
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Mucho congratulations to Rob.
You're one of the most deserving people I know of, for an honor such as this.
Keep up the great work, sir.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 09-15-2003, 10:53 AM
Keith Chester's Avatar
Keith Chester Keith Chester is offline
HGFSP
FRC #0025 (Team 25)
Keith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to behold
Send a message via AIM to Keith Chester
I remember when I first began my venture into programming for my team Rob was there to help me not only set up the program and showed me how to run it, but also pointed me in the right direction on learning to program. I would still be lost if it wasn't for his kind guidance.
Thanks for the help Rob, you deserve this!
A proud graduate of 25.
Students. Teammates. Brothers.
Proud member of R.I.N.O.S., Rookies In Need Of Support.
Unread 09-15-2003, 11:03 AM
sanddrag sanddrag is offline
back to school ;-)
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Programming is not all that he does either. He's helped set me straight on more than a couple mechanical things. Thanks man!
Support Team 696 on DonorsChoose!
Unread 09-15-2003, 03:01 PM
Unsung FIRST Hero
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
I met Rob this year when I started trying to do the autonomous workshops at UCF and working on making sample codes for teams to use as guides, and he was the first one to walk over and say "What can I do?" Then later when I had my own problems, he came right over and helped out. At UCF, overnight they left the AC on and it rained, sucking water right into Cogsquad's robot since they were in the corner. Rob and his teammates set right to work and performed some miracles, and he can work under the stress and keep thinking strategically, even if a chunk of their robot is taken off during a match I saw many teams using his RoboEmu software to test out their code, while the pit crew worked on the robot, then they'd be ready to go when the pit crew was ready, without ever needing to use the robot, just to tweak some numbers. You deserve this Rob, excellent job!
Chopsaw?
Co-owner of Stream Monkey
Member of Robot in 3 Days
Unread 09-15-2003, 03:15 PM
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
You have no idea how helpful RoboEmu has been. You rock Rob!
1139 Alumni
Unread 09-15-2003, 04:24 PM
Ryan Foley's Avatar
Ryan Foley Ryan Foley is offline
AKA: Foley
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Wow, I can't think of anyone better to win this award. All his programming expertise has been a help to so many people. RoboEmu is the best thing in the world too (for robot programming).
Congrats Rob,
Thanks for everything
Ryan Foley
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC Volunteer:
2010: Referee [WPI Regional, Mayhem in Merrimack], Robot Inspector [BAE Regional]
2009: Referee [BattleCry 10]
2008: Referee [Connecticut Regional, BattleCry 9, Beantown Blitz, River Rage 12]
2007: Referee [Beantown Blitz, Mayhem in Merrimack, BattleCry 8, River Rage 11]
2006: Referee [UTC Regional, Beantown Blitz, Mayhem in Merrimack, BattleCry 7, River Rage 10]
2005: Referee [Mayhem in Merrimack, BattleCry 6]
Unread 09-15-2003, 05:03 PM
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Hey, thanks for the great robotics software
I know it's always helped out our robot.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 09-15-2003, 05:11 PM
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
I believe this really does deserve to go to Rob.
When I was having problems connecting to the RS-232 port for my FIRST Editor, he wouldn't mind if I ask a slew of questions really. He's also a cool guy all-around.
His programming skills are those second-to-none for FIRST IMHO. RoboEmu helped team 5 during our debugging stage before we shipped the robot (it helped way more than many cank think). RoboGUI is also an essential part of team 5 really. It really helped period.
To me, he is one-of-a-kind (all of us are really though ). I wish him the best in his college years, and whatever he makes of himself. He deserves all the accomplishments that he gets.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 09-15-2003, 06:22 PM
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
Oh come on.. its just Rob.
Just kidding! This guy is too smart for his own good, and has been a huge help to everyone! You the man Rob!
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 09-16-2003, 08:27 PM
Ken Delaney's Avatar
Ken Delaney Ken Delaney is offline
#0357 (Royal Assault)
Ken Delaney is an unknown quantity at this point
Send a message via Yahoo to Ken Delaney
Congrats to Rob. This recognition is well deserved. His RoboEmu was invaluable for testing our code last year. I also think Rob should be thanked for how quickly he posts concise answers to people questions. When ever I see one his posts I always stop to read it and usually learn something new. I just hope he comes out with a new RoboEmu if the change the controllers.
Ken Delaney
"Dare mighty things!"
Unread 09-18-2003, 07:34 PM
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
Congrats rbayer!
You're a cool guy.
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 09-19-2003, 07:20 PM
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
Thanks everybody! Your thanks and appreciation makes everything all worthwhile, and as long as Robo* continue to be useful, I'll continue trying to keep them reasonably up to date.
Thanks again to everybody! I'm truly honored to be selected as an UFH.
-Rob
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
UFH Forum Strangeness Greg Ross CD Forum Support 5 11-05-2003 09:53 PM
No QotW and No UFH! Rich Wong Rumor Mill 4 11-04-2003 07:46 AM
UFH: Christopher Hibner CD47-Bot Unsung FIRST Heroes 8 10-20-2003 07:08 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
