pic: Doubble-wishbone Crab fender
That's a great idea, but would you use it on a robot?
I have to admit I have NEVER seen that combo before.
Tytus,
I deffinatly give you a A+ for creativity. Some problems that i see, your robot "chassis" is going to be very small, becaus those suspension stuts are going to take up a big chunck of space. also how are you going to rotate each pod? i noticed that each drive module is powered by one shaft out the top. are you going to attach 1 drive motor to run all those pods or are you going to have individual wheel w/ a motor? Thats a really good idea, run with that |
You need for the wheels in each module to be pointing in the same direction to work, obviously. It appears as if you planned on using belting that's common to two or more modules to achieve that.
I hope you've considered timing belt as an option or something else than won't slip. Slipping, over time, will throw off the alignment of your modules relative to one another. More importantly, I don't understand how that belting is supposed to remain attached to a crab module that's going up and down on a suspension. Perhaps a better explanation of how the belting would interact with the frame and other modules would reveal how this works? |
Why do you need a suspension? For more tire contact at all times? Surface area doesn't affect traction.
im thinking of going in the Half-shaft direction instead of the Kevlar for Propultion, the steering could be all linked for simplicity or all indivdual steeper-motors for some crab,Quadrosteer,and other wikid cool tricks. Please Feel free to throw your own ideas in there, it would look kinda like a starfish with 4 points, i know Its dard to Keep track of the scale of things in 3DS-MAX
Don't ignore deformation. |
mmkay, here goes:
Originaly posted by you, M: If your wheel is a smooth surface (i.e., aluminum, two wheel chair wheels), double the area will do nothing to aid your traction at all. It will increase by a factor of 1. So you are saying that on a smooth regular surface, the surface area doesn't matter. Ok, so how about an irregular surface where the tire and and surface can intermesh, say on carpet? From the whitepaper,: When the surface area went down the friction increased Wait, is this saying that not only did the traction not go down, it went up? Hmmm.... |
#10
However, it can be true and has been true in FIRST in the past. How do I know? I designed a drivetrain that was, apparently, stronger than 250 or so others and it was based entirely on deformation and the meshing of irregular surfaces. |
#11
Traction can go both ways with surface area. Rock crawler 4x4s (and sand vehicles) air down their tires for a bigger footprint. More suface area and more traction. But some 4x4 mudders (and snow vehicles) use really skinny tires so they can sink into it and get a bit on what's on the bottom rather than float over on top. I know this isn't really about traction on FIRST robots but it was the first example I could think of. There are just so many variables involved that it really depends on the exact materials and the exact situation.
Traction is such a complex issue that it's really not worth debating about because everyone is right and wrong, just in different ways. There are so many factors involved: tread, interlocking surfaces, surface area, friction, composition of both tractive surfaces, stickyness, softness of both surfaces, gravity, and that's just the beginning of them. Nascars have smooth tires on a very smooth surface but get incredibly good traction. 4x4s have very aggressively treaded tires on very uneven surfaces but get incredibly good traction. There is a different kind of tractive surface that works best for every terrain. And it being the best is only in the eyes of the operator. There are way too many things that make up traction for any one person to be right about what works the best for everyone. Just do what you think works good and let everybody else do what they think works good. Problem solved. |
#12
Very impressive Tytus.
Only downside I see is it's size. If you wanted to put that on a FIRST bot you might want to shrink it down, so that you have more room available for electronics and any other mechanisms. Keep up the good work |
#13
The reason I think it looks big is because I'm imagining a wheel the size of the wheels in the kit as the wheel in your design, which is what, 6 or 8in diameter?
Hopefully you can build one sometime, I'd love to see a bot with that on it. |
#15
the skyway wheels are about 9.5 inches in diamater, I know itS WAY off scale
| pic: Coaxial Lego doubble-wishbone crab | CD47-Bot | Robot Showcase | 7 | 12-10-2003 11:10 AM |
| pic: Crab Concept 6 | CD47-Bot | Extra Discussion | 13 | 11-14-2003 09:03 PM |
| pic: Tytus Coax Crab Fender | CD47-Bot | Extra Discussion | 9 | 09-27-2003 11:17 PM |
| pic: Tytus Crab Drive lego model | CD47-Bot | Extra Discussion | 11 | 09-08-2003 05:36 PM |
| pic: 217 Gen 2 Crab Module Section view | CD47-Bot | Robot Showcase | 2 | 04-28-2003 05:26 PM |
