Go to Post FIRST is not advanced shop class - KenWittlief [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 11-01-2003, 07:34 PM
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Inertial Navigation System
Hi I was thinking about prototyping an Inertial Navigation System and was wondering what gyros and accelerometers team 190 used last year in there's and were they obtained them.
Unread 11-02-2003, 04:17 PM
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
we are doing the same thing. According to our programmer, the program is ready, we just need some accelerometers.
I check small parts, and msc, but they are both more mechanically oriented.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 11-02-2003, 04:42 PM
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
I know they use them in cars for measuring G-Force, so they might be with automotive things
Hows my searching? Call 1-800-Green-Dots
Unread 11-02-2003, 05:55 PM
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Analog Devices makes some pretty cool Accelerometers and Gyroscopes.
Kevin Watson
Engineer at Space Exploration Technologies (SpaceX)
http://kevin.org
Unread 11-02-2003, 06:25 PM
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Blarg... a flashback from early last season...
I built an inertia navigation system, based around a Basic Stamp 2. I have the schematics and code someplace, AIM me if u want them (ExtrudedAluminiu)
The system I built was based around a three axis accelerometer and three gyros. The acellerometer and gyro outputs were integrated by op-amps (analog circuits!!) and then fed to an ADC. The BS2 would select the data it wanted, and it would read it in. It worked remarkable well on my desk. =)
I also placed a 1-axis accelerometer, and ADC, and a BS2 into a model rocket. The BS2 was supposed to read the ADC and then store the output in its onchip EEPROM. However when i tested it, the BS2 couldn't keep up with the incoming data, and I missed large enough chunks that the height that i obtained was useless.
Btw, all the accellerometers i used were from Analog Devices. They work great for projects and FIRST things.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 11-03-2003, 12:15 AM
Rpifirst Rpifirst is offline
AKA: Nuz
#1493
Rpifirst is on a distinguished road
Send a message via AIM to Rpifirst
I know that 190 was going to write a white paper or rather we thought we should. Tommorow I will ask the lead designer of the INS about it for you. I know however that the we used a prefab mini controller along with some two axis accelerometers that I believe are normally sold in mass quanities. Also I know that it took a team of 4-5 the six week's to do altogether.
Nuz
Lambda Chi Alpha
E.H.1103
Unread 11-03-2003, 08:00 AM
catlin101's Avatar
catlin101 catlin101 is offline
#0461 (West Side Boiler Invasion)
catlin101 will become famous soon enough
accelerometers
I did something kind of like that last year, except I did this:
I had a gyro chip, and then rotary encoders on the wheels. I was worried about using an accelerometer, because in order to get position, you need to integrate them twice. So, once the velocity gets off by a little bit, your position will start "drifting." I never actually tried using an accelerometer; maybe this isn't as big a problem as I thought.
Unread 11-03-2003, 08:18 AM
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
You may want to check with teams 111 and 308 also.
Andy B.
Planning for 2013
Unread 11-03-2003, 08:27 AM
AKA: Nuz
#1493
I talked to rick petty the lead designer of the ins and he said soon he will have a full website on the ins we used in 2k3 when he has it finished ill post it here.
Nuz
Lambda Chi Alpha
E.H.1103
Unread 11-03-2003, 08:39 AM
Eric O's Avatar
Eric O Eric O is offline
AKA: Eric O'Brien
FRC #0177 (Bobcat Robotics)
Rookie Year: 2000
Eric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond repute
Send a message via AIM to Eric O Send a message via Yahoo to Eric O
Stangs Site
You may want to check out the StangPS presentation that they have on their site if you have not checked it out yet. Here is a link to the original thread about StangPS:
http://www.chiefdelphi.com/forums/sh...hlight=stangps
Eric
Eric O'Brien
Team 177 - Bobcat Robotics (00-01,06-?)
Team 229 - Division by Zero - Clarkson University (02-05)
Unread 11-03-2003, 01:24 PM
AKA: Allen Gregory
Weren't we only supposed to use additional electronics form digi-key or future FAI?
Unread 11-03-2003, 03:00 PM
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Yes. Digikey sells nice microcontrollers and Future sells angular rate sensors and accelerometers by Analog Devices and other manufacturers. Between these two sources, you can get everything you need to make a nice navigation system.
Unread 11-03-2003, 03:46 PM
AKA: Nuz
#1493
We bought both the accelerometers and microcontrolers form places other than future and digikey. I'm not really sure about the gyro it could be the one from the kit.
Nuz
Lambda Chi Alpha
E.H.1103
Unread 12-02-2003, 07:34 PM
AKA: Allen Gregory
Re: Inertial Navigation System
Then wouldn't your robot be considered illegal.
  #15   Spotlight this post!
Unread 12-02-2003, 10:23 PM
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
I have some ADXL2002s (i think) lying around somewhere. They are pretty nifty and extremely sensitive.
Hint Hint: engineering samples
1139 Alumni
Electrical componenets for autonomous navigation maclaren Electrical 10 12-18-2003 01:28 AM
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 08:49 AM
Scoring system for 2004? DougHogg General Forum 11 04-16-2003 07:57 PM
control system worth more than $500 archiver 2001 8 06-24-2002 01:00 AM
New Innovation FIRST control system and the dashboard archiver 2000 0 06-23-2002 09:15 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
