Go to Post I've found that housework is more fun with power tools. - RogerR [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 01-01-2004, 06:31 PM
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
how can you use a gyro in autonomous mode
Hi! i just have a question since i am very new programmer. Okay i know how to create an autonomous mode but how can you use gyro's in autonomous mode. please show me a code so i can have a look at it and learn. thanks by the way my e-mail address is jigarjuhi@yahoo.ca. thanks guys for your time and co-operation.
Unread 01-02-2004, 12:18 AM
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Team Role: Leadership
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Re: how can you use a gyro in autonomous mode
I shouldn't even be writing this, but i felt like i needed to. The second topic in this forum asks the exact same thing (found here:http://www.chiefdelphi.com/forums/sh...ad.php?t=23268) and i gave them the following response:
Originally Posted by myself in another forum
one piece of advice, before bringing up something that is not completely obscure, search the forums and also just go the the appropriate forum and make sure to change the start date from one week to one year or something along those lines. here's one forum on gyroscopes and C and the like:
http://www.chiefdelphi.com/forums/sh...ad.php?t=23071
I cannot say it enough, search, search, search!
As i just realized though, that doesn't give autonomous code. All a gyro can really do is tell you which way you're pointing, nothing more. So there really is no way to give sample code except for the following which just integrates the gyro output to give you one number which shows how far you've turned.
Code:
int theta=0;  //in global variables
// from here on in autonomous section or what have you
signed char gyro = (GYRO-127)*G_ADJUST; //GYRO being the macro for wherever your gyro is attached
                                          //and G_ADJUST is a constant to adjust to degrees
if (theta+gyro>=360)  //rolling from 359 to 0 and around again
   theta+=gyro-360;
else if (theta+gryo<0)  //rolling from 0 to 359 and around again
   theta+=gyro+360;
else
   theta+=gyro;
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 01-02-2004, 01:18 AM
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Rookie Year: 1996
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
I cannot say enough that posting "I need code to use the gyro" or "I need autonomous code" is akin to saying "I need a design for an arm for my robot" in the mechanical forum. In order to get a useful answer you need to make your question more specific. What should the code do? Should the code simply read the value of the gyro and discard it while driving forward for 5 seconds? Should the code make sure the robot drives straight? Should the code drive straight ahead, turn 90 degrees, then drive straight ahead again? In engineering requirements are key. We cannot help you if we don't know what you need help with.
Mike
Unread 01-02-2004, 12:31 PM
GregTheGreat's Avatar
GregTheGreat GregTheGreat is offline
GregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura about
I know what the best bennifit of a gyro is (in my mind)... I consider it a backup device... using it with your counter you can make a very sound auton. program. I am searching through my programs last year to find an example of what I am talking about but my programs are on my old computer so when I backed them up on CD's they got thrown all over the place.
Basically it would work like this....
you could use a go-sub like this
Code:
	Gyrocounter:
	if sensor1 > 130 then Gyro1:             'Gyro Sensor Clockwise
        if sensor1 < 128 then Gyro2:             'Gyro Sensor Counterclockwise
	Goto Gyro3:
	Gyro1:
	cont = cont + sensor1 - 129
	Goto Gyro3:
	Gyro2:
	Gyro3:
	Pass:
	Return
Then incorperate your code like this....
Code:
         Right_Gyro:
	gosub gyrocounter
	if cont < 32000 then
	relay1_fwd = 1 		'Two Wheel Drive On
	relay1_rev = 0 		'Four Wheel Drive Off
	endif
        On indc goto RGyro, RGyro1, RGyro2, RGyro3, RGyro4
	RGyro:			'Half Circle
	p1_y = 175		'Right Front Wheel Forward
	p2_x = 175		'Right Rear Wheel Forward
	p2_y = 250		'Left Front Wheel Forward
        p3_x = 250		'Left Rear Wheel Forward
	If cont > 37800 then RGyro1
	Goto Main:
	RGyro1:			'Half Circle
	indc = 1
	relay1_fwd = 0 		'Two Wheel Drive Off
	relay1_rev = 1 		'Four Wheel Drive On
	If cont > 38200 then cycle = 0
	If cont > 38200 then goto RGyro2
	Goto Main:
	RGyro2:			'Straight Forward
	indc = 2
	p1_y = 253		'Right Front Wheel Forward
	p2_x = 253		'Right Rear Wheel Forward
	p2_y = 253		'Left Front Wheel Forward
	p3_x = 253		'Left Rear Wheel Forward
	If cycle >= 130 then RGyro3
	Goto Main:
	RGyro3:
	indc = 3
	p1_y = 127		'Right Front Wheel Stop
	p2_x = 127		'Right Rear Wheel Stop
	p2_y = 127		'Left Front Wheel Stop
	p3_x = 127		'Left Rear Wheel Stop
	If cycle >= 140 then RGyro4
You can get the basic idea on how to program a gyro (id the variabales)
REMEMBER
This is pbasic coding you will need to convert it into C for this years controller... on Innovation they have the "pamphlet" they created to show you how to do many of these functions... I will work on making some C programming for a gyro but I have many other things to work on for my team so I do not know how productive I will be...
If you need help with the coding give me something to work with... a general idea is hard to show you what you want but if you give me a very spacific idea I would be more than happy to help you out ne way I can.
If you need the help contact me...
AOL IM- GregTheGreat04 (no spaces)
E-mail- g.ullstam@comcast.net
Good Luck,
-Greg The Great
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 08:32 AM
autonomous mode problem on field Chris_C Programming 17 03-26-2003 06:11 PM
Autonomous mode AntmanIV General Forum 1 02-17-2003 12:30 PM
autonomous mode timer Don Programming 6 02-09-2003 09:16 PM
autonomous mode? bigwalt Technical Discussion 1 01-21-2003 12:14 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
