Go to Post IYou might get it all changed over and discover your robot has trouble moving from a dead stop, can no longer turn without playing morse code on the breakers... - KenWittlief [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Authentic Touch Landscape
ADVERTISEMENT
Unread 01-11-2004, 01:58 PM
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
Question Centering, and other tools, in Inventor?
I can't figure out how to center the parts in an assembly.
I also forgot how to rotate, using a keyboard, and resize using a keyboard.
Any help would be apperciated.
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 01-11-2004, 02:01 PM
Paul Marshall Paul Marshall is offline
Paul Marshall will become famous soon enough
Send a message via AIM to Paul Marshall
Re: Centering, and other tools, in Inventor?
Not exactly sure what your question is, but you can place a constraint on the centerline of a cylinder. Hope that helps.
-Paul
Unread 01-11-2004, 06:40 PM
LBK Rules's Avatar
1467 '06 Alumni
no team (HSRO)
What I mean is something like in max, you can enter the XYZ location/orientation, and it corrisponds, rather than using the mouse to move/rotate it.
Anthony Rinaldi
Team 1132: 2003
Unread 01-11-2004, 09:18 PM
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
Go to the "3D spin mode" and click space bar, then you can move the object in a set range of rotation. I'm not sure if that answers your question but it always helps when draw something wrong and you need to make it look like its in isometeric view when its really not.
Unread 01-13-2004, 03:07 PM
R2K2D2 R2K2D2 is offline
Technical Advisor
AKA: Raj
R2K2D2 has a spectacular aura aboutR2K2D2 has a spectacular aura about
Send a message via AIM to R2K2D2
I don't know if I really understand what you are asking. What do you mean by "centering the parts in an assembly"? If you mean how do you get a specific piece in the middle of another piece, you just need to use regular constraints. Once you have placed the constraint all you have to do is use the offset feature in order to orient one piece in the direct middle of another. Let's say you have a 2"x2" block and u want to place a 1"x1" block exactly in the middle of the 2x2...We can put a mate command between both surfaces which will attach the two pieces together. Then, we can put a flush constraint on the top of both pieces and to the left of both pieces. Now the 1x1 will be squared up in the upper left hand corner of the 2x2. Then in the Model Tree go and find the two flush constraints. Choose one of them first and at the bottom of the Model Tree there will be a little box where you can set the offset. So, set a horizontal offset to the middle of the 2x2 and a vertical offset to the center of the 2x2 and now you have constrained the 1x1 box in the middle of the 2x2 box. Hope this helps and if this really wasn't what your question was referring to, post a more specific one or just feel free to ask me, id be more than happy to help.
Unread 01-14-2004, 01:40 AM
maclaren maclaren is offline
AKA: Dexter
FRC #0997 (Spartan Robotics)
maclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of light
-To Zoom you hold F3 down
-To Zoom all there is NO hotkey or shortcut you simply have to go to the button that looks like a box with four arrows pointing from the inside to the outside edge.
-To Rotate you hold F4 down
There are very few hot keys in inventor. I think that this is the biggest down side to inventor. The fact that you have very limited abiltity to customize your user interface is a bad idea.
Unread 01-14-2004, 11:31 PM
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
If you have a mouse with a wheel...
Hold down the middle mouse button (wheel) - this will pan the view
Move the scroll wheel in and out - this will zoom
To zoom to a specific part (or parts):
Select the part you wish to zoom to (for multiple parts hold down ctrl while you select them).
Hit the "zoom to enities" button on the view toolbar (I attatched a image, the button you want has a red box around it in my image).
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
