Go to Post First off, let me suggest that you read the rules! There is an amazing amount of really good information in them. - dlavery [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 01-14-2004, 12:55 PM
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Warning: Error in beacon assembly directions included in the kit!
Everyone,
While assembling our IR beacons we discovered that the "First Infrared Beacon" assembly sheet that was included in the kit is incorrect. The connections to pins 2 and 3 of the FET are reversed. FIRST has been notified, and I hope they'll release updated directions to address this. In the meantime, if you know your way around electronics you should be able to take care of this yourself (search for IRL3103 on Google if you'd like to look at the datasheet for the FET included with the kit). If you don't know exactly how to modify the circuit to be correct, I'd recommend that you just wait to assemble it until new directions are released.
For those interested, you can see where the error is by looking at the sheet included in the kit and examining the schematic that represents the internal "guts" of the FET and compare it to the schematic right at the top of the datasheet for the FET. You'll notice that the FIRST version has pin 3 connected to the "D" (for Drain) line of the FET, but if you look at the "Lead Assignments" on page 8 of that same datasheet that Drain is really pin 2.
P.S. Thanks to Kevin Watson for confirming this to make sure I wasn't making a fool of myself
Unread 01-14-2004, 03:17 PM
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Warning: Error in beacon assembly directions included in the kit!
Originally Posted by Dave Flowerday
Everyone,
I've whipped-up a replacement schematic that can be found here: http://kevin.org/frc. The data sheet for the IRL3103 is also there. For those interested in electrical engineering terminology, this type of circuit is called a "low-side switch" because is switches the ground or current return side of a load as opposed to a "high-side switch", which switches the power or current source.
-Kevin
Kevin Watson
Engineer at Space Exploration Technologies (SpaceX)
http://kevin.org
Unread 01-15-2004, 07:23 PM
FRC #2429
The resistors in the schematic should be 33 ohms, not 330 ohms. The 33 ohm color code is orange-orange-black; 330 ohm is orange-orange-brown.
-Kevin
Kevin Watson
http://kevin.org
Unread 01-15-2004, 07:32 PM
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
Thanks for the update Dave. I'll make note of that when we start soldering that up tomorrow.
Programmer
Team#857
Superior Roboworks
WildStang Alum
Unread 01-16-2004, 07:14 PM
Eko's Avatar
Eko Eko is offline
Eko is an unknown quantity at this point
Is there an online version of the PDF that we can download? This would probably updated much earlier than they can distribute anything, and even if it is erroneous, our electronics lead could do whatever you just said =)
Unread 01-16-2004, 07:22 PM
FRC #2429
Yes, just use the schematic I mentioned above.
-Kevin
Kevin Watson
http://kevin.org
Unread 01-17-2004, 02:31 PM
KBMSora's Avatar
KBMSora KBMSora is offline
#0486 (Positronic Panthers)
KBMSora is an unknown quantity at this point
Thanks for the info. We were having some trouble figuring out what was going wrong.
Unread 01-17-2004, 08:50 PM
Gary Bonner Gary Bonner is offline
FRC #3974
Rookie Year: 2000
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Is the diagram FIRST posted yesterday correct?
Unread 01-17-2004, 09:01 PM
FRC #2429
Yep, it looks like the MOSFET drain and source are where they should be.
-Kevin
Kevin Watson
http://kevin.org
Unread 01-17-2004, 10:34 PM
Software Engineer
Rookie Year: 1995
But the connections TO the drain and source on the FET still look incorrect! The updated diagram only changed the little schematic inside the FET but they didn't update the connections from the LEDs and ground to match.
Unread 01-17-2004, 10:58 PM
FRC #2429
Yeah, I spoke too soon. The connection diagram is messed-up too.
-Kevin
Kevin Watson
http://kevin.org
Unread 01-27-2004, 03:36 PM
FRC #2429
Just FYI, The FIRST folks are about to post the corrected beacon construction document.
-Kevin
Kevin Watson
http://kevin.org
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
