OCCRA   [more] Florida Regional : 109d 14h 30m ...
Go to Post Drive yourself, ride Amtrak or Greyhound bus, or bend space-time to the point of singularity and you'll just poof into existence in Atlanta. - artdutra04 [more]
Go Back   Chief Delphi > Other > Math and Science
Team 47   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
HEXBUG Nano
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Delphi
ADVERTISEMENT
Old 01-17-2004, 06:50 PM
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Calculating Wheel Size To Climb
It seems like one prevalent method that will be used this year to get onto the platforms will be to utilize big wheels. I tried to calculate how big such a wheel would be needed using a 130lb robot but didn't come up with a way to do it. Can someone with a deeper physics background explain the method?
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Old 01-17-2004, 07:17 PM
Cory's Avatar
Cory Cory is offline
On to 2009...
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Calculating Wheel Size To Climb
Generally, I believe that you need 2/3 of the wheel to be beneath the step. Anyone with a physics background care to confirm/deny this?
Cory
*2001-2004: Team 100
2005:
*Sacramento-Inspector/Referee
*UTC-Field Reset
*SVR-Inspector/Referee
*Nationals-Inspector/Referee
2006-???: Mentor, Team 254
Old 01-17-2004, 07:23 PM
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Calculating Wheel Size To Climb
The short story is that any 4-wheel driven drive train could climb up the 6" lip assuming the coefficient of friction is high enough and the motor torque was high enough. However, the true problem is in "bottoming out" ie where the bottom of your robot or some component will actually scrape along the edge of the step before your back wheel climbs the back step.
To ensure this doesn't happen you can just choose a wheel size that has a radius larger than what you wish to climb, and mount it such that the bottom of your frame is taller than the 6" step- you're able to let both wheels stay in constant contact with the ground.
However, one should note that there exists a very real fear of tipping. A robot with a high center of gravity could potentially tip while attempting a feat such as this. If you would like some calculations for when tipping occurs, please let me know.
I hope this (briefly) points you in the right direction.
As to Cory's comment about 2/3's... I've never heard of such a thing, though I know that a wheel with a radius higher than the step size will have a mechanical advantage, since you simply need to rotate about the point, as opposed to climb the wall.
Good luck!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Old 01-17-2004, 07:36 PM
Cory's Avatar
On to 2009...
AKA: Cory McBride
Matt, you are right, we tested our robot out last night, using a piston to lift up the front of the robot. The one we used only got us to about the midpoint of our wheels, but since we had so much torque, we were able to drive right up. If you do it all in one continuous motion, and you have enough torque, you actually wont high center the frame. If you stop midway, however, youre stuck.
I believe the reason I heard the 2/3's thing was so that you could know exactly how large of a wheel would get you over, no questions asked. I very likely am wrong though.
Cory
2005:
*UTC-Field Reset
Old 01-17-2004, 08:00 PM
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
I would like to see the tipping calculations.
Old 01-17-2004, 08:10 PM
ngreen's Avatar
ngreen ngreen is offline
Robohyo
AKA: nelson green; robohyo
None #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Send a message via MSN to ngreen
Our robot from last year was able to climb a six inch step with a slight modification. We added two non-driven wheels on the front to lift the front up to the first set of wheels. This was with a four wheel drive system with 8.5" wheels that have lots of traction (go-kart racing slicks). We are planning on going to a 10" pneumatic tire though. We want to smoothly make our way onto the platform, not ram our way up.
Nelson Green (Panther Robotics 1108)
Chemical Engineering 2007, K-State
Grad School: Georgia Tech (for PhD)
2007 GKC KCP&BE Award
2006 Wisc Chairman's Award & Website
2005 Purdue Chairman's Award & Galileo Finalist
2004 LSR Chairman's Award & Xerox Creativity
2003 LSR Champ,Quality & Team Spirit + Nat All-Star
Old 01-18-2004, 02:37 AM
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
Watching and Waiting
no team (TBA)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
There are more variables to consider than just wheel size. MIT's 2.007 course has some very good info on this subject online. There's even a handy Excell spreadsheet for calculating the ability of wheeled vehicles to climb obstacles. Link follows:
Wheel Climb.xls
-Joel
Old 01-18-2004, 05:04 AM
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
As Joel said, wheel size is not the ultimate determining factor for climbing stairs. One good example of this is the Personal Rover Project's Rover1, which can climb a 7 inch step with 2 inch wheels.
Zan Hecht
Scorekeeper: 2005 Championship DaVinci Field
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Old 01-18-2004, 06:23 PM
Eric Thompson's Avatar
Eric Thompson Eric Thompson is offline
Go patriots!
#1415 (Astroguard)
Eric Thompson is an unknown quantity at this point
My team is wanting to get up the platform on the side in order to bypass the "small" space where the goals are. Is it possible to have a two wheel drive in the front with casters in the back and still be able to get up the incline? One of our team's teachers said that it was possible but im having doubts about it bottoming out. The person that designed the drive system or body says that the robot can and/or will be 6in or below from the floor. Im just the Arm Captain, but am I freaking out or what?
Eric Thompson
Northside High
Team 1415
Columbus Georgia
Old 01-18-2004, 06:36 PM
Anne Shade Anne Shade is offline
Moving on to bigger/better things?
AKA: Formely Anne Bergeron
Rookie Year: 1998
Anne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond repute
Send a message via AIM to Anne Shade
I would really advise against having castors in the back if you want to climb. The big problem with castors is that you can't control their orientation so it will make it very difficult to control the direction of your robot with your back end spinning away. Having skids or non-powered wheels would be better than castors. Even better would be a 4 wheel drive. If you have any questions about how to do this, email me. The GT FIRST group in GA is here to help all the GA teams as much as we can. You can also IM me if you need to at Astroanne10.
Anne Shade
Past Teams: 132, 408, 608, 832, 1002, and 2377
Old 01-18-2004, 08:44 PM
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
You dont need big wheels to climb a step
ever see a kid go UP a curb on a skateboard?
with a little momentum your wheel doesnt have to hit the face of the step at all - if you get creative :^)
BTW - did I ever mention that when I was a kid, "Speed Racer" was my favorite saturday morning cartoon?
Old 01-18-2004, 09:52 PM
ngreen's Avatar
Robohyo
We know their is much more than wheel size but is does help in several ways. Higher clearance and more lift by an indivual wheel. We are testing 8 wheeled designs. 3 driven and 1 not. From are test we might be able to use eight but it is much smoother with 10 for us. and a inch in height will not through our center of gravity off much. Using four wheel drive you could climb the step with two wheels. The robot would have to have a lot of clearance and large wheels, say bigger than 12". Two wheel drive with casters would be hard, it might be possible but I wouldn't reccomend it.
Old 01-18-2004, 10:49 PM
Jedi Padawan's Avatar
Jedi Padawan Jedi Padawan is offline
Electrical Expert Student
AKA: Dan Howell
Jedi Padawan is on a distinguished road
Send a message via AIM to Jedi Padawan
I beleive the numbers one of the engineers on our team from a tire company decided you would need somewhere in the ballpark of 18 inches to "comfortably" climb the 6-inch step. We quickly decided on a better method....
It's all fun and games till the bosh motor breaks.....
What size monitor do you use? Elgin Clock IT / Communications 30 03-10-2004 04:53 PM
how can you use a gyro in autonomous mode magical hands Programming 3 01-02-2004 01:31 PM
Who used wheel encoders CyberWolf_22 Technical Discussion 12 05-04-2003 03:37 PM
A file size issue Funkymunkey90 3D Animation and Competition 2 02-05-2002 02:50 PM
"Motors and Drive train edition" of Fresh From the Forum Ken Leung Bulletins and Newsletters 6 01-29-2002 12:32 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
