Mounting Joysticks?
I was wondering how we can mount the joysticks in a semi-permanent manner?
The new ones have section cups, but they are to temporary. |
Re: Mounting Joysticks?
There is tape available that has a foam core and adhesive on both sides. We used this tape last year and it worked fairly well.
Cory |
Are we allowed to use tape on our OI controls even though we are only supposed to use tape for electrical insulation.
The rules only apply to the robot, your Operator's board can be however you like it. Use common sense and dont put anything dangerous on it though
Cory |
I think we are able to modify the joysticks how you want because the rule about tampering with the joysticks is not in the rule book this year. Unless I missed something but I don't think I did.
we use velcro on ours. It works well.
We built a metal bracket that fits into the little ridge at the top of the joystick.
How about a real semi-permanent, permanent, or temporary solution: tie wraps. Placed on the edges of the joystick, I've seen them used for a couple of hours, up to a whole season.
As Ryan said "velcro" thats the best thing I can think of it holds up so well
#10
keep in mind you don't need a wide area for the operator controlls. You just need enough space for 2 people. Make something that will fold up and is lite that won't harm the operator system. and as others previously stated velcro is the way to go.
#12
Well, if you don't want it permanent, then I would have to say (larger) velcro would be the way to go. If you do want it permanent, drill out a few holes in-between the screws holding the base of the stick to the top. On whatever you're mounting it to, drill out holes for the screws holding the base on, and the holes you just made. Unscrew the base and bolt it onto your plate through the newer holes, then screw the base back onto the top through the remaining holes in your plate. We've used it for 3 years, no prob.
#13
I would say that tie wraps (zip ties) are your best bet for mounting a joystick in a semi-permanent manner. Velcro and other adhesives tend to get sticky.
| drill motor mounting | whynot | Technical Discussion | 3 | 02-03-2003 07:24 AM |
| Sideways mounting | srjjs | Electrical | 13 | 01-25-2003 07:31 PM |
| new bosch pinion and mounting | ajlapp | Motors | 1 | 01-08-2003 04:16 PM |
| Could use some help with joysticks . . . | archiver | 2001 | 5 | 06-23-2002 10:36 PM |
| Calibrating speed controllers and joysticks | thedillybar | Technical Discussion | 4 | 02-11-2002 12:24 PM |
