| View Poll Results: Were teams successful with a tank tread drive? | |||
| It worked all the time. |
18 | 43.90% |
| It was a nightmare. |
6 | 14.63% |
| It sometimes worked but always required constant maintenance. |
17 | 41.46% |
| Voters: 41. You may not vote on this poll | |||
Success with Tank Treads
Poll: Were tank treads easy, hard, or ok to deal with for teams who have tried in the past? Basically, did they function well all the time, some of the time, or were they a nightmare?
Re: Success with Tank Treads
It seems like me that it would be too difficult to turn in a game like this where maneuvaribility is very important and power not so much.
Dont be so quick to assume that
I think we'll see some pretty powerful bots. |
well lets see *opens super secret robot design* i think some teams might be thinking differently this year, and go with power *closes super secret robot design, then gets a cheeseburger*
Treads are not trivial to design, build, and maintain. While they might not be to the level of "nightmare", they sure cause some sleepless nights.
The advantage of treads are: 1. Increases your ability to climb things 2. Provides a bit more traction, depending on the playing surface The disadvantages of treads are: 1. Requires more weight allotment compared to wheels 2. Reduces your driving power due to a less efficient drivetrain (the belts must be pulled very tight in order to stay on, causing high side loads on your pulleys and bearings) 3. The cost is very high (more expensive bearings, numerous pulleys, costly treads, more spare parts). 4. They take longer to design and build. Our team has never been able to get a tread system driving before week 4. Prepare to have very little drive practice. 5. Losing a tread = losing a match If you are putting treads on your robot, keep your belt tight, keep your pulleys aligned, and be sure to put a "bow" on the bottom surface of your tread (middle pullies should be lower than outer pullies). That's just my opinion. Others might have had an easier time with these treads, but after putting them on team 45's robot for 4 out of the last 5 years, this is how I see things. Andy B. Last edited by Andy Baker : 01-19-2004 at 10:14 PM. |
In 2000 237's bot originally had tank treads (I know, can you believe it?
), which basically lasted through our practice rounds at UTC. I couldn't go that day, but the people who came back looked crestfallen...the thing was slow as molasses and was too troublesome. After our practice rounds, the pit crew made the decision to switch to wheels...and it was the best decision we could have made. We ended up seeding in the top 8 and walking away with the win.I'm not saying that treads are always a bad decision....they do have their good points (Baker already listed them above)...and I trust that they went through all those pros and cons before they decided to originally use them. In the end, it's just a personal decision your team has to make. Use these pros & cons, compare them with what your team wants to be strong at and the answer will be clear ![]() |
618 went with treads last year and did well. While I do agree with the simplicity arguement against treads, who said life had to be simple!
http://www.valleytech.k12.ma.us/robo...2%20Monday.jpg
We have been doing tracks for 10 years now. The most important thing is you power train. if you get your power just right the tracks work great. We found out how much power a track can take. What we did was speed up the track which lowers the power. This way the robots is fast and still have great pushing and pulling power. with out ripping the tracks Tracks are very costly but done right is very easy to drive under auto mode and very easy for the driver to control. Last thing you need to keep your center of gravity as low as you can. this also helps out the tracks |
I think we actually did win a qualifying match in 2002 with a broken belt, but we were already in pretty good position when it snapped. The bow in the bottom (middle wheel lower) is a gotta have - we call that the "boogie wheel" because it allows you to turn on a dime without dragging / slipping the belts. Ours is spring loaded. A couple other down points to consider: Brecoflex belts (by far the best we've used) are very expensive and have a long lead time (probably why we were never driving until week 5) Maneuvering takes longer and is harder to do in short spaces because of the added side drag. Metal-in-Motion made the Finals with belts last year, so as far as success is concerned this is only one aspect that you need to make work for you if you choose. |
#10
I would say both robots were quite equal in power. but I think you had 2 speeds becuase you were quick off the mark. I hope to see you this year in UCF. Back to the tracks the best thing about them is if you do turn sideways not many if any could push you. |
#11
Take a look at the new tracks for this year. a nice new look with a strong 1" shaft. Last year we spun 4 of our drive shafts, to much power so we are running with 1" this year.
http://www.valleytech.k12.ma.us/robo...photos2004.htm |
#12
Very spiffy looking pulleys you have there. Looks like we'll be seeing another powerful bot from 61 this year
![]() Cory |
#13
Looks sweet again Mike - and to the point of this thread, you can see how much design and machining time goes into making a tread system work. The sprocket you see there comes solid stock, just the teeth and the bore cut; all the weight reduction getting to the cool looking spokes and the attachment holes plus the drive shaft takes design, NC programming and machining time.
#14
Our team this year(134) has taken advantage of the awesome breckoflex tracks, they are totally amazing, a self tracking feature? who woulda thunken! and hey CD...Pembroke this year will be a force to be reckon with. ![]() Last edited by Greg Perkins : 01-21-2004 at 01:06 PM. |
#15
http://www.valleytech.k12.ma.us/robo.../2004VIEW1.jpg
http://www.valleytech.k12.ma.us/robo.../2004VIEW2.jpg http://www.valleytech.k12.ma.us/robo.../2004VIEW3.jpg http://www.valleytech.k12.ma.us/robo.../2004VIEW4.jpg http://www.valleytech.k12.ma.us/robo.../2004VIEW5.jpg Here are some pictures in cad to give you a better look at a simple track design |
| tank treads vs. threaded wheels | lj8758 | Technical Discussion | 14 | 01-23-2003 11:30 PM |
| Under or Over? To tank or Not to tank that tis the question! | archiver | 2001 | 2 | 06-23-2002 09:53 PM |
| TANK TREADS...welp. | archiver | 2001 | 13 | 06-23-2002 09:50 PM |
| pneumatics tank | archiver | 2000 | 2 | 06-23-2002 09:43 PM |
| What problems have you encountered using treads? | M.I. | Technical Discussion | 8 | 01-15-2002 09:13 PM |
