Go to Post A shaft that yielded is just as useless as a shaft that broke. - Chris is me [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Cross the Road Electronics
ADVERTISEMENT
Unread 01-30-2004, 09:11 AM
Brawler006 Brawler006 is offline
#1206 (Wrench Warriors)
Brawler006 is an unknown quantity at this point
# of solenoids
The competition manual is kind of ambiguous in this area. Is there any limit to the number of soledoids that you can use on your robot?
The part use flowchart says that you can use any pneumatic compnent from any year's kit of parts, but is also says that you cannot use a motor, pump, solenoid, or actuator that was not included in the kit of parts. Can anyone clarify? Thanks
Unread 01-30-2004, 09:20 AM
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: # of solenoids
the pneumatic solonoids are really valves that happen to contain a solonoid.
the way i understand it we are allowed to use the same type of valvess they gave us this year, as many as you need to control the cylinders on your bot
since you can have an unlimited number of cylinders, it wouldnt make sense to only let you use the quantitiy of 3 valves they supplied in the kit.
Unread 01-31-2004, 04:09 PM
Matt Fultz's Avatar
Matt Fultz Matt Fultz is offline
Matt Fultz has a spectacular aura aboutMatt Fultz has a spectacular aura about
Re: # of solenoids
According to the current rule book, you can have unlimited pneumatic cylinders and solenoids. The details for pneumatics are in the FIRST rule book and pneumatic book.
Unread 01-31-2004, 05:43 PM
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
KevinB will become famous soon enoughKevinB will become famous soon enough
Send a message via ICQ to KevinB
Re: # of solenoids
The way I understand the rules is that it is unlimited.
Unread 01-31-2004, 05:55 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: # of solenoids
You are right that it is ambiguous. <R54> says you may use them if they are off the shelf. However, the parts use flow chart says you can't. This is a question that you must ask FIRST.
Unread 02-01-2004, 10:12 AM
Gary Bonner Gary Bonner is offline
FRC #3974
Rookie Year: 2000
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Re: # of solenoids
It looks like off the shelf solenoid valves are ok. You do however, have a limited number of digital outputs...
Q: R54 states there is no limit to number of solenoid valves. They must be off the shelf. The flow chart seems to contradict this. May we purchase other off the shelf solenoid valves?
A: You may purchase other off the shelf solenoid valves. We will modify the flow chart accordingly.
Q: What are the total number of cylinders that can be used on the robot?
A: <R54> clearly states "There is no limit to the number of solenoid valves, air cylinders and fittngs you may use on your robot."
Q: In 5.2.9 It is stated that There is no limit to the number of solenoid valves, etc you may use on your robot. The part use flowchart would seem to only allow solenoids from last year's kit. May we obtain other solenoids to use?
A: You may obtain other solenoid valves. Be sure to verify that their coils are specified to operate at 12 Vdc.
Double Solenoids - assembly. Frank(Aflak) Pneumatics 9 02-06-2003 07:33 PM
solenoids from last year Antonio Pneumatics 6 01-29-2003 09:59 PM
solenoids hot69z Electrical 2 01-08-2003 05:02 AM
solenoids zarb Electrical 1 01-28-2002 10:19 PM
solenoids rdmendola Electrical 1 01-26-2002 03:58 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
