Header rows on the R/C
Has anyone found a proper header or connecter to use with the input rows on the R/C. I havent had much time to check it out for myself and i would hate to use a bunch of cd-rom to sound card cables for their ends. I am going to try and measure the pins and check out NIO and the other electronics suppliers. If this has been covered in another thread or has been posted I would appreciate a link to it.
Re: Header rows on the R/C
I can't say for sure, because I don't have the controller here with me, but unless they changed something, a standard PWM cable should fit it.
Bill |
Right now, we're using IDE cables salvaged from old computers. We just need to cover the signal pin for each 3pin set, so having two rows isn't a big deal. If we find something cheap that works better, though, we'll probably be quick to use it.
$5 each, from Innovation First, is pretty steep. Tower Hobbies' $8 isn't any better. |
3-conductor housings: jameco.com, part number 157382, $0.24
female crimp pins: jameco.com, part number 100765, $0.09 The documentation describes how to use them. I use the cheap crimper from Radio Shack. Buy 50% more crimps than you need because you will mess up a lot until you get the hang of it. A pack of three housings w/ 9 crimps from the local hobby shop costs $6.00. |
http://rocky.digikey.com/scripts/Pro...A9BAG-0308F-ND
I think these are a good thing for the headers, then you just extend. when i get them i'll let you guys know. |
-Kevin |
your the man kevin, rep points to you
Thread: "digital i/o connectors"
http://www.chiefdelphi.com/forums/sh...23&postcount=5 Last edited by DanL : 02-04-2004 at 10:31 PM. |
| Header Not Found (adc.h) | NotQuiteFree | Programming | 2 | 01-23-2004 03:26 PM |
| Needing A header file | jweric | Programming | 19 | 01-23-2004 09:25 AM |
| How to connect the R/C receiver?! | Tim Skloss | Robotics Education and Curriculum | 7 | 12-10-2003 03:34 PM |
| EDU R/C Based Robot | Venkatesh | Technical Discussion | 2 | 12-02-2003 02:20 PM |
| R/C Control types | Andy Brockway | Programming | 43 | 11-24-2003 04:07 PM |
