Go to Post yeah, right - like anyone's going to pass up building a robot. - IbleedPink233 [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 02-13-2004, 07:44 PM
Richomundo's Avatar
Richomundo Richomundo is offline
Mascot
AKA: Richie Knight
#1115 (Deus Ex Machina)
Richomundo is on a distinguished road
Send a message via AIM to Richomundo Send a message via Yahoo to Richomundo
problem with joystick buttons (top left one)
we are having a problem with the top left black button next to the FOV mini joystick on the joystick that FIRST has provided us.
our top right button works however....
i'm thinking maybe we dont have the correct variable. here is our code:::
/* 2nd joystick open globe motor arms */
if (p2_sw_aux1==1)
{pwm01 = 200; }
else if (p2_sw_aux2==1)
{pwm01 = 55; }
else {pwm01=127;}
the else if statement is where i think the problem is but I'm not entirely sure.
help would be helpful.
THANKS
love, richie
I got the mic and you got the moshpit
Unread 02-14-2004, 07:45 PM
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: problem with joystick buttons (top left one)
that looks correct - you can even simplify it as such:
Code:
if(p2_sw_aux1)
    pwm01 = 200;
else if(p2_sw_aux2)
    pwm01 = 55;
else
    pwm01 = 127;
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 02-15-2004, 06:27 AM
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
That should work. Try reading the OI data under Dashboard and see what the values the buttons on the joystick is putting out. It may be that the button is broken. Our top right on one of the joysticks is sticky and doesn't work reliably.
In case anyone doesn't know, there is a jumper next to the dashboard port on the OI that can be moved between RC and OI. Set it to OI and you see the values coming in on the ports of the OI.
Unread 02-15-2004, 04:10 PM
Richomundo's Avatar
Mascot
AKA: Richie Knight
Talking Re: problem with joystick buttons (top left one)
thanks every one. the problem has been solved. the joysticks are really crappy and i think both of them are broken. it wasn't the code as we thought.
gracias.
Unread 02-15-2004, 04:14 PM
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
gracias.
open up the OI pdf file. there is a list of pinouts. the reason the button wont work is that not all the buttons are connected to a pin. if you put the joystick in port 2 the button that is not working is probably routed threw to port 3. you might want to look at the pin outs and see if this is your problem.
Unread 02-15-2004, 04:16 PM
Richomundo's Avatar
Mascot
AKA: Richie Knight
we just got new joysticks.i opened one **one of the old ones** up and some wires had come off and the little green board had a crack in it.
Victor problem Andy Baker Electrical 15 06-24-2003 08:49 AM
robot goes haywire with the one joystick default code Miles Programming 7 01-24-2003 01:58 PM
Assigning Joystick buttons.... archiver 2001 5 06-23-2002 11:59 PM
joystick problem archiver 2000 12 06-23-2002 10:08 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
