#16
Re: Relay Aliases Backwards
And as I prevoiusly stated Quote:
#17
I would like to confirm that the the alias's are backward. Relay fwd should be green light, ours was red.
My question is has IFI released a default program that is correct? |
#18
There are two reasons why the manufacturer of the compressor would like the polarity observed for the compressor motor. A) The fan in the motor was designed to move the most air with the least noise/power when turned in one direction only(axial fans). That direction will be when you observe the correct polarity. (result- motor will run cooler and longer) B) Almost all series wound DC/AC universal motors or PM DC motors have the commutator shifted with respect to the main magnetic field to minimize commutation arcing. So they are most efficient when turning in the direction of the default polarity( e.g. the recommended polarity). This is the reason why the motor will not produce the same rpm/power in either direction. (Also, a radial fan operates equally well in either direction, an axial fan (like the compressor has, does not.) When such a motor is reversed, the commutation can be seen to arc more than the forward case, this arcing will cause the brushes and commutator life to be reduced, the commutator temperature to rise. Further, the arcing represents energy lost and hurts the overall efficiency of the motor. (Efficiency is what you get/what you pay for...) Motors can be designed to work the same in either direction, but at an overall loss in efficiency. So, bottom line: wire the compressor backwards will work, but will run hotter, use more power and produce less work, and will have a shorter life than normal. |
#19
We at Innovation First have confirmed the problem you have noticed. The root cause is that the silkscreen labels (REV/FWD/GND) on the Robot Controller are incorrect, and the aliases in the Default Code were set to match them. The simplest fix is to swap the reverse/forward aliases in ifi_aliases.h, as some of you have already done, and to ignore the REV/FWD/GND labels.
Another option is to swap the connections on the M- and M+ outputs of the Spike Relay Module to achieve the correct polarity. New Default Code with these aliases fixed will be on our web site soon. A note will also be placed in the 2004 Robot Controller Reference Guide regarding the incorrect labels. Regards, Innovation First, Inc. |
#20
| relay and pwm outputs | nick_champ_2 | Electrical | 1 | 01-31-2003 12:08 PM |
| Wiring the relay for the pnumatics | Placebo | OCCRA | 3 | 11-05-2002 10:04 PM |
| Spike Relay Input | nwagers | Electrical | 3 | 07-16-2002 09:23 PM |
| NEED HELP with Delay loop for compressor relay switch | archiver | 2001 | 10 | 06-24-2002 01:11 AM |
| Relay Outputs | OddOne | Technical Discussion | 3 | 02-01-2002 06:52 PM |
