Go to Post [in response to http://www.welovefirst.com/] I feel like I've just been FIRST Rick Rolled. - kramarczyk [more]
Unread 02-16-2004, 06:17 PM
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
mounting the electronics
a couple questions from a rookie team..
is it really BETTER to have them mounted on a non insulating surface?
is it better to have them mounted on a board that is easily deattachable from the robot?
is using velcro to mount each individual component a good idea?
is it not a good idea to mount them to our frame directly using velcro?(our frame is aluminum)
how easily accessible should they be?
is it a bad idea to need to flip the robot over to take out the battery?
has there been any accidents that you know of where any part excluding the motors and fuses had to be replaced completely due to any reason other than physical disturbances?
how what gets HOT? the motors..... the victors? well they already have fans on them...
well anyways, please tell us what is BAD. and what we need to worry about or what we need to be careful of or what has to be however (other than whats on the manual)
just don't want to do anything wrong! thanks!
Unread 02-16-2004, 06:28 PM
Tom Bottiglieri Tom Bottiglieri is offline
Custom User Title
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Send a message via AIM to Tom Bottiglieri
Re: mounting the electronics
Would i say it's better to mount everything to a board? NO
well then again, we have a wood base.
Team 254 | San Jose, CA | Mentor (2010 - Present)
Team 125 | Boston, MA | College Student (2007 - 2011)
Team 195 | Southington, CT | Student (2002 - 2006)
Unread 02-16-2004, 06:33 PM
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Personally, I think an insulating surface is better for electronics - there is less of a risk of a short if a wire falls off. That being said, aluminum is stronger than plexiglas and most other insulating surfaces.
As for easily detachable... Yes, it is definitely a good idea to make all wires as accessible as possible. A detachable panel may be a good thing.
Velcro, in my opinion, is a very bad idea. It is not strong enough for what the bot will have to endure during the match. If the velcro falls off, so does your RC/speed controller, then the wires are going to be ripped off, and you'll short the battery. Definitely not a good idea
Motors and fuses going bad... It could happen, but it did not to our team. You can check fuses with an ohmmeter to see if they are ok. As for motors... You can bring spares if you want (it would be the best thing to do), but if you cant get spare motors, FIRST should have a limited supply at the competitions.
The motors should not get hot if your gear ratios are right. If they do get hot, a fan will not solve the problem. There was already a thread about this.
Of course, anything could go wrong at any time Just do your best to avoid obvious mistakes.
Unread 02-16-2004, 06:34 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
[quote=greencactus3]a couple questions from a rookie team..
Much less can go wrong from uninsulated wires and connectors if they can't touch something big and conductive
I can see the advantage of this, but in 8 years I've never felt it was worth the time to do so. Especially since you are this late in the season, I wouldn't try.
Personally, I like bolting them down better. However, This year, about half our components are velcroed down. When used in large quanties, velcro is quite strong on a horizontal surface. I wouldn't put it on the edge of mounted vertically with velcro, though.
see above about mounting to a conductive surface. Also, if it is on the exterior, I'd be worried about other robots running into you.
Seeing that you are a rookie team, you more then likely will have electrical problems that need to be solved quickly. They don't need to be in open air, but it also shouldn't take more then a minute or two to get to them. You also shouldn't have to pull an contortions to work on them.
the battery has to be easily accessible, per the rules. You also have to demontstrate this to the inspectors. I do not beleive this meets that criteria.
If you get metal in the speed controllers, they will release the magic smoke.
That's pretty much it.
Unread 02-16-2004, 06:35 PM
occra 23.
AKA: ryo
None #1481
Originally Posted by OneAngryDaisy
is it better to have them mounted on a board that is easily deattachable from the robot?- Yes. If you add a new motor or component you won't want to bend over the robot for 10 minutes shifting wires-
how? a couple bolts?
is using velcro to mount each individual component a good idea?-NO! a direct hit could knock something off, imagine losing your entire left drivetrain thanks to a collision-
again, how? i don't think glue'll work. or wait were there hole for bolts on each one?
is it a bad idea to need to flip the robot over to take out the battery? Um.. yes... flipping over 130 pounds of metal isn't pleasant, and in the playoffs you'll have to replace it often-
or how about crawling under and replacing? i don't know how big the pit area is... well, our robot is quite high off the ground and it might be nice to have more weight below than above. not worried itll flip or anything but just MIGHT be better
Unread 02-16-2004, 06:43 PM
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
1. Is it really BETTER to have them mounted on a non insulating surface?
This year, we constructed our electronics "deck" to be removable from the robot, so a board made sense. If you are careful with your wiring, you don't need a board at all. It has made things easier for us, though.
2. Is it better to have them mounted on a board that is easily deattachable from the robot?
In the hectic scene of the pits, will you have time to remove a deck, check wiring, check code, recheck wiring, and recheck wiring again, and then reinstall the board? Remember the number of devices that much be connected. We tried using terminal blocks to keep all the wire that interfaced the board with the 'bot separate, but our board ended up affixed.
3. Is using velcro to mount each individual component a good idea?
Honestly, I wouldn't trust velcro for components so critical. However, if you are able to construct stable mounts with velcro, and happen to have spare components, go for it. Velcro knots and meshes might be strong enough.
4. How easily accessible should they be?
Anything that can go wrong will. Robots that should move won't. Robots that shouldn't, will. Speed controllers will explode, resembling small atomic bombs (really), relays will jam, etc. Accessible components are a good idea.
5. Is it a bad idea to need to flip the robot over to take out the battery?
Can you (1 person) change a battery in an emergency in under 2 minutes? If so, good. Personally, I like to have the battery as accessible as possible, especially if a robot frame is aluminium. In the off chance of a short, you can do something. However careful wiring can eliminate that problem.
6. Has there been any accidents that you know of where any part excluding the motors and fuses had to be replaced completely due to any reason other than physical disturbances?
We have had speed controllers (victor 883s) which appeared to work, but the electrolyte in the capacitor had dried up, and they didn't actually power the motors. We have never had problems with relays, spike red or blue. In fact, we have never even blown a fuse on the relays. Our main problems have been more physically oriented (physical damage, etc).
7. how what gets HOT? the motors..... the victors? well they already have fans on them...
The victors get hot, but not very hot. I believe that the Victors act like the Tekin Rebels, generating the greatest heat at low speeds. I'll have to check that sometime. Motors (especially the drill) get very hot after significant run times. Last year, we had a drill motor reach a temperature where they were far too hot to touch, and that was after roughly 10 minutes of running. I personally like to cool them, but I don't see too many robots that do so.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 02-16-2004, 07:32 PM
occra 23.
AKA: ryo
None #1481
how about 884s? i think thats what we are using. also, a red spike and a blue spike? is that the difference in the letters? whats the REAL difference? is one better than another? please explain
Unread 02-16-2004, 07:54 PM
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
Rookie Year: 2000
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
For mounting the board- yes, we usually have a lexan board bolted to our robot so whenever something needs to be changed our programmer can whip it out. However, after 'building' season ends, we usually leave it intact.
All of the components should have holes for attaching small bolts.
about crawling under, if you guys make a cart then you shouldn't have to crawl under.. but thats a big if, we didnt even have a cart our first 3 years :/
Unread 02-16-2004, 08:02 PM
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Did FIRST change the rules about using tape? I dont think you can use velcro tape (sticky on one side) on your robot - you can use velcro belts or loops to hold your battery in - but last time I read the rules the only 'tape' you could use was electical tape, and not to hold things together, only for insultation.
Unread 02-16-2004, 08:07 PM
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
Yes. Last year, our chassis was a sheet of 1/4" aluminum. We mounted the electronics directly to it, and found it very annoying - it increases the likelihood of accidental shorts, and it means that you have to either tape up or remove sensitive components before drilling holes or making modifications. It's more trouble in the long run than simply making a separate electronics board out of non-conductive material.
That depends on how accessible the board is. If you can reach it easily without having to dig through everything else in the robot, not necessarily. If you can't fix wiring easily with the board installed, then make sure you can detach it quickly.
No. The force of bent wires trying to unbend themselves can be sufficient to force components loose from even the heaviest Velcro. We tried this in 2001, and it made a mess. The electronic components all come with holes drilled in them so you can bolt them to things. Use them.
Aside from the usual Velcro concerns, doing things this way makes power distribution a nightmare. If you mount your electronics to their own board, you know that you won't end up needing to mount other things to that, and you won't have to rework your wiring all the time when changes are made to other things.
Obviously, you need to be able to access the main breaker fairly easily. For troubleshooting and maintenance purposes, it's a very good idea to make all the other components as accessible as possible. Last year, our electronics were very poorly organized, making it difficult to troubleshoot problems and repair or replace things when necessary. After that, I made sure to make this year's board as neat and accessible as possible, and it's been a dream to work on so far.
Yes. The battery is something that you will want to be able to access very quickly and easily.
Battery shorts can make wires melt. Victors are always happy to vent their magic smoke. Crimp connections can fail. Assume everything is unreliable until proven otherwise.
If your gear ratios are good, the motors shouldn't get TOO hot under normal circumstances. The Victors already have their own fans, but you might want to consider putting additional fans near them if your electronics are enclosed in an area that is not well-ventilated.
Unread 02-16-2004, 08:50 PM
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
KevinB will become famous soon enoughKevinB will become famous soon enough
Send a message via ICQ to KevinB
The difference between the 883's (discontinued) and 884's is that the 883's have a larger deadband around the center (they provided control of approxmately 10-100% power in each direction, whereas the 884's provide ful 0-100% control in each direction).
The Spike Reds (long discontinued) defaulted to the "on" output state on both channels unless they were told by the RC to be "off"; the Spike Blue defaults to the "off" output state (safer).
Unread 02-17-2004, 06:39 AM
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Green Cactus,
You have a lot of good answers here, I am proud of all that responded. For us, we have used velcro in the past but were living with the experience of the bad speed controllers of the mid 1990's. For the past few years we have used perforated aluminum as a base, tywraps to hold things in place. We space parts out when we can to help with heat buildup (everything gets hot, motors most of all. Circuit breakers when they are continuously tripping too.) Parts should be accessible, if you get into the finals you won't have a lot of time to replace stuff so you want to be able to change it out quick. We have mounted our battery in a doored compartment under the robot for years. So you have to turn it over to change it, so what, you can't drop it on the RC accidently from there. If your wiring is insulated to begin with, you may not need to have the mounting surface insulated. Wood and lexan weigh a ton but a lot of teams use those materials for construction.
Al
WB9UVJ
www.wildstang.org
________________________
Professional electronics board assembly [annotated collector's edition] Geoff General Forum 7 02-17-2004 08:57 PM
Question about buying electronics _GP_ General Forum 5 02-01-2004 11:43 AM
drill motor mounting whynot Technical Discussion 3 02-03-2003 07:24 AM
new bosch pinion and mounting ajlapp Motors 1 01-08-2003 04:16 PM
mounting electronics nwagers Electrical 10 02-15-2002 12:09 PM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
