Go to Post What happens when everything becomes fully swagged out? Also, does my robot need to have collar-popping functionality to use every feature? - AlecMataloni [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 02-17-2004, 08:21 PM
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
None #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Send a message via AIM to Chris_Elston Send a message via Yahoo to Chris_Elston
MPLAB Variable Simulator?
This is really the first time I've used this MPLAB software and the first time I've coded in C language. Normally I code in Ladder Logic, (Programming Logic Controllers), Visual Basic, or what ever proprietary language or mnemonic language of the week that might be in whatever servo controller I get my hands on. However I’ve notice a nice tool in MPLAB I'd like to know a bit more about.
When I program my C program offline, I see that I can use the MPLAB simulator much like a Visual Basic debugger. The problem is I can't see or figure out how to simulate variables to keep executing in my code. Example:
My offline debugging gets STUCK in a loop here:
PHP Code:
* FILE NAME: ifi_utilities.c
* DESCRIPTION:
snippppeddd a few lines of code…..........................................
/* Used when transmitting data serially.  It waits for each byte to finish.   */
void Wait4TXEmpty(void)
#ifndef _SIMULATOR
while (!TXINTF)
    continue;
#endif
I need to be able to SIMULATE the variable !TXINTF so that I can get past this part of the code while performing a STEP function in the debugger. I am sure may other spots will be required to be simulated imputs also to get the loop area where the user code is executing. Is there anyway in MPLAB to setup this variables and many more to toggle or force values?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 02-17-2004, 08:27 PM
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: MPLAB Variable Simulator?
what you actually need to do is define the macro "_SIMULATOR" - hence the #ifndef lines around that particular loop. there are certain parts of the code that will get stuck without that macro defined. just go into the mplab project settings window and look for where you can define preprocessor macros, and add _SIMULATOR to the list.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 02-17-2004, 08:37 PM
Controls Engineer
AKA: chakorules
I eye! Captain. Found it under Build Options. Well give that a whirrlly gig..
Favorite CD quote:
Unread 02-18-2004, 11:08 AM
Mark McLeod's Avatar
Itinerant Programmer
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
You'll also find yourself running into problems if you are using the internal timer interrupts. The easiest way around that is to add your own #ifdef _SIMULATOR around the timer initializations to turn the interrupts off for debugging.
"Always exaggerate. It makes life seem more interesting." - Robert Weber
Interrupt Handlers and Variable Scope kaszeta Programming 2 02-14-2004 05:30 PM
If you're having MPLAB problems, LOOK HERE. Jeremy_Mc Programming 0 01-20-2004 05:06 PM
Im am having trouble with the MPLAB hedgehogger Programming 7 01-19-2004 04:37 PM
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 11-03-2003 12:24 AM
what teams have a variable transmissions? Greg Perkins Technical Discussion 4 03-06-2002 05:10 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
