Go to Post You can't please all the people all the time. The rationale of "lots of people don't like it" is not a reason to stop doing it. - Karthik [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
The Chrysler Foundation
ADVERTISEMENT
Unread 02-18-2002, 11:10 AM
Joe Canavan Joe Canavan is offline
#0125 (NU-TRONS)
Joe Canavan is an unknown quantity at this point
Question Triping Timed Fuses
We are having a problem tripping our timed 30Amp Fuses when we go from forward to revers quickly on our drive traine. We are using the Drill motors and we believe that our traction on our wheels is causing the motors to stall when direction is reversed quickly. Can anyone recomend a fix either in hardware or in programing to help over come this tripping of our breakers? Thanks
Joe
Team 125
PS sorry about spelling errors we have been up all night.
Unread 02-18-2002, 01:03 PM
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Here's the acceleration code we use to make sure the drivers aren't crunching gears... Use it ONLY if you learn something from it. Take a look and figure out how it works...
Code:
SAFE_ZONE		CON	1000
MAX_ACC		CON	10
MAX_ACC_VAL 	CON	SAFE_ZONE + MAX_ACC
MIN_ACC_VAL 	CON	SAFE_ZONE - MAX_ACC
left_motor:
	if (abs(left_control - 127) > DEAD_ZONE) then left_calc
	left_control = MOTOR_OFF
left_calc:
	speed_l = speed_l + (((left_control - speed_l + SAFE_ZONE) min MIN_ACC_VAL max MAX_ACC_VAL) - SAFE_ZONE)
right_motor:
	if (abs(right_control - 127) > DEAD_ZONE) then right_calc
	right_control = MOTOR_OFF
right_calc:
	speed_r = speed_r + (((right_control - speed_r + SAFE_ZONE) min MIN_ACC_VAL max MAX_ACC_VAL) - SAFE_ZONE)
Unread 02-21-2002, 08:34 AM
ttedrow's Avatar
ttedrow ttedrow is offline
Hearding electrons.
AKA: Tim Tedrow
FRC #0281 (EnTech)
Rookie Year: 2000
ttedrow will become famous soon enough
Exclamation First order filter
Here is solution to your proplem that has been passed down by FIRST programmers for many moons (also on the InnovationFirst WEB site). This first order filter will limit the rate of change of the inputs.
Drive_yFiltCoef CON 50 'First Order Filter Coefficient = CON/200
Drive_xFiltCoef CON 20 'Adjust these values for improved control. Trial and Error.
Drive_yFilt VAR byte 'First Order Filter output for the Y-axis Joystick Input
Drive_xFilt VAR byte 'First Order Filter output for the X-axis Joystick Input
'**First order filter to limit rate of change of drive motors**
Drive_yFilt = (Drive_yFilt + ((256 + p1_Y - Drive_yFilt) * Drive_yFiltCoef / 200) - (256 * Drive_yFiltCoef / 200)) Min 0 Max 254
Drive_xFilt = (Drive_xFilt + ((256 + p1_X - Drive_xFilt) * Drive_xFiltCoef / 200) - (256 * Drive_xFiltCoef / 200)) Min 0 Max 254
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Team Mentor '00-'03, '11-'13
FLL Coach '06-'12
Palmetto Regional Lead Inspector '04-'07
Palmetto Regional Planning Committee '08-'09
Palmetto Regional Safety Advisor '08-'09
World Festival FLL Judge '08-'11
20 amp fuses for Spikes Andrew Schuetze Electrical 8 04-01-2003 09:18 PM
Blowing Relay Fuses archiver 2000 2 06-23-2002 08:57 PM
Internal Fuses (PTC Resistors) on Window Motors bigqueue Technical Discussion 6 02-08-2002 08:34 PM
Those 60Amp fuses... Anton Abaya Electrical 5 01-18-2002 06:41 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
