Go to Post A thread already exists (and boy, does it exist!) on the topic: - Billfred [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 03-10-2004, 02:35 PM
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
An inspired alumnus
AKA: Jamie Bliss
no team (previously 904 (D-cubed) and 1227 (Techno-Gremlins))
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Send a message via ICQ to Astronouth7303 Send a message via AIM to Astronouth7303 Send a message via MSN to Astronouth7303 Send a message via Yahoo to Astronouth7303
Question Getting Long Data
How do you get a Long (signed or not) from the FRC to you?
I'm currently using printf() in a way so that, basically:
Code:
void printl(long Num)
 //Print Bytes
 printf("Long %d %d %d %d\n", (int)(Num>>24)&0xFF, (int)(Num>>16)&0xFF,
     (int)(Num>>8)&0xFF, (int)Num&0xFF);
 //Print Words
   printf("Long %d %d\n", (int)(Num>>16)&0xFFFF, (int)Num&0xFFFF);
The problem is that the thing seems to want to increment higher sections to soon. In a pattern.
Code:
0 0 0 8
0 0 1 9
0 0 1 16
0 1 1 17
(or:
Code:
0 8
1 9
The other option is to use 4 user bytes. but we only have 6. well, 4 User + 2 LED + 1 UserCmd.
Can anyone offer suggestions? This little bug really affects results. (bland understatement)
Unread 03-10-2004, 03:29 PM
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Re: Getting Long Data
{snip}
The problem is that you're printing out each byte of the long as a base-10 number. Try using %x instead of %d. That way, you'll get the right numbers out, but they'll be in hex. If you want it in decimal, your best bet is to modify printf_lib.c (specifically the printi function) to accept long arguments.
Unread 03-10-2004, 04:08 PM
Mark McLeod's Avatar
Itinerant Programmer
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
I just put some routines here http://www.chiefdelphi.com/forums/showthread.php?t=26529 that do this.
You can just call the one routine that prints decimals without changing any of your own printfs.
"Everyone you will ever meet knows something you don't" - Bill Nye
Competition Scouting pauluffel Scouting 31 01-08-2003 11:34 PM
Robot Scouting Database archiver 2001 10 06-24-2002 02:00 AM
Limiting PWM in pbasic archiver 2001 4 06-23-2002 11:38 PM
How long should production time be??? archiver 1999 4 06-23-2002 10:16 PM
Possible Configuration to keep things cheap archiver 1999 8 06-23-2002 10:03 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
