#61
Re: You write <G34> and <G35>
I'm saying overly harsh based on current rules. This is what we are discussing right? It is hard to judge intent. You can't quantify it that tipping or damaged robot wasn't built poorly so that it was partial at fault. I'm only suggestion to leave it subjective but give the refs better tools to work with. The yellow cards would allow for teams to not do the same thing in consecutive matches. You might get away with tipping or overly aggressive actions in one match of final but now you could do it all two or three. And you only get 2 dq before you get dqed from the game. And don't forget finals rule, a dq for a team in elims is a dq for that alliance. I think the cards would suffice. |
#63
Just some clarification and examples:
![]() Quote:
However, this brings up the point of teams purposely building shoddy robots just to get their opponents dq'ed. This would be up to the inspectors to notice and prevent. (Prevent from competing until the robot is more robust) Quote:
), our hook was quite badly twisted. This happened because our robot, who was hanging, was pushed by another robot attempting to mount the platform. This is not card worthy, because our hook still functioned. (We were still hanging)MrToast |
#64
I like the idea of a card system.
I also like the CONCEPT of a Penalty Box, where a machine is disabled for a FEW seconds as a penalty for a Yellow Card warning. However, I feel a 7-10 second penalty would be more than enough to "warn" and punish them, vs a 15 second penalty. BTW, in any case IMHO the arena control system should have a Disabled Light at each player station, at the shelf level. Maybe have a big yellow bulb attached off of the back of the mini Kill Button Box, or a countdown display there, showing the operators how many seconds remain in your Penalty. No one thinks to notice that the light above their heads is out while they're furious shaking their controls wondering what's wrong with their robot. It needs to be between eye and waist level. - Keith |
#65
I really like the yellow/red card idea. The big problem with these kinds of aggressiveness calls is that in a lot of cases it almost impossible for the refs to tell the actual intent of the drivers. If a robot tips another, did they actually mean to tip them or were they just trying to move them out of the way? With a defensive move a robot is broken, was it the intent to break the other or was that just a bad design? Refs can't be deciding whether or not damage was the fault of another team or whether or not it was a design issue. Refs already have so much that they have to be keeping track of on the field, we do have to keep in mind that they are only human.
With the yellow/red card idea, this gives the refs a chance to warn teams that a certain action will not be accepted by a team. That also gives the team a chance to change what they are doing. As a coach, I know how intense it can get up on stage and yeh sometimes we may make a bad call without really realizing it. Having a warning system in place that tells the team to not try that again or you will be DQ'ed I think is the way to go. |
#66
I like like the combination yellow red card approach. I also like the time based penalty a little better. (not just because it was my idea)
For instance, in the match that started this whole mess 93 vs 469, I think it would have been adventagous to issue a 10 second penalty to 469. My problem with the yellow card: in order for the yellow card to come out a questionable act has already occured. |
#67
Im saying that match results would be different with the rules I proposed on page one the match was NOT illegal as it was played and called according to the official rules because the driver was only thinking good thoughts when he drove across the field at full speed and rammed the bot knocking it over if he had been thinking bad thoughts, "Im gonna drive across the field at full speed and knock that bot over" then he would have been DQ's - and somehow the refs could tell the difference ?! Im getting zinged with negative rep points for my opinions in this thread, thats why I tried to explain the difference between the way the game was played/called this year, and the way I would LIKE to have seen it played/called I guess my opinion is unacceptable? Quote:
guess not Last edited by KenWittlief : 04-21-2004 at 12:07 PM. |
#68
I'm missing your point. |
#69
the yellow card will look cool next to the agressive teams champion trophy, thats the point
#70
Can you give me examples where robots went past the point where robots get knocked over? Most of tipping situations I saw as soon as the robot started tipping, the other backed off, but the robot tipped anyway. I just think a lot of what has been discussed and expressed in this thread is unrealistic, exaggerated, and if some of the rules are implimented, will take a lot of the fun out of the game. I mean, how much fun will it be if: a) the kids are afraid to push another robot because if they tip, they are dq'd. b) they push other robots, causing them to tip, getting them dq'd. We'll have dq's all over the place. |
#71
MrToast, once again enjoying the [COLOR] tag WAY too much ![]() |
#72
http://www.chiefdelphi.com/forums/sh...7&page=1&pp=15 |
#73
You know what? I'm going to design a really great new autonomous passenger aircraft. I've also found a way to reduce weight and increase passenger capacity by removing redundant structural elements. Due to fuel savings, increased passenger capacity, and reduced personnel requirements, air travel costs will be drastically reduced!
But ... Clouds, flocks of birds, solar flares, and weather related electrical disturbances will cause the plane to crash, and certain atmospheric density variations or wind effects will critically compromise the air frame. So ... I'm writing up a proposal to disallow the environmental phenomena listed above. Doesn't work in engineering, and it shouldn't work in FIRST. |
#74
Robot problems that might result in a dq result from other robots, not the carpeting of the arena. Good try, though. |
#75
What about automode? What happens if they run into each other and one flips over or gets rammed? How do you penalize or DQ someone for that? Or maybe we'll just add another rule that says... if tipped during automode, no penalties incur...Or maybe make up some crazy detailed rule for it.. Or maybe we get rid of automode, or maybe we say... robot can only move 1ft/s during automode.... Now, if we create a rule that says "if you're totally legal pushing action results in tipping your opponent", then why do we have any incentive to play any kind of defense, or even build a good offensive robot? We've already determined that obvious ramming and "intentional" damage is illegal. But we start putting these detailed guidelines on "what is legal defense", we might as well put a big black wall in the center of the field so that there will be no robot interaction. There will be no need for a competition. These drivers will be so worried about going anywhere near another robot. Like said before, if your robot cannot withstand some pushing and shoving in any way, you've probably got some things to look at and re-design. Otherwise, we better start building robots that can hold hands and hum together. ![]() Last edited by AmyPrib : 04-21-2004 at 01:01 PM. |
