how fast are you
I am interested to find out what most teams cruizin speed/gear ratio is. I thnk this would be helpful to most other teams trying to build a transmission. Thanks in advance for the responce.
Re: how fast are you
We top off at about 14 feet per second with a gear ratio of 4-1(to get more complicated it's, 60:24:12)
Our robot cruises at about 7 fps. I don't know the gear ratio. This was our fastest bot. Others can match @ top speed.
p.s. what is up with the name stealing? j/k Last edited by Jeremiah Johnson : 05-09-2004 at 05:20 PM. |
We have a theoretical top speed of 9.4 fps. We run on drills and Chias. The Chias are geared down to match the speed of the drills (in low gear), then the drills are geared down 12/32 to the 12.5" diameter wheels.
Team 188 has a low speed of 4 fps and top speed of 17 fps.
We ran a test witha mostly full battery and we are at about 11 fps
Our robot's original top speed was 15 fps.
It's now down to around 9.5 fps. Cory |
high gear 15 forward 300 RPM
low gear 9-9.5 forward 231 RPM |
well....I have run a mile in 4:30
#10
our bot goes 11.9 ft. per second on high gear... and 3.4 feet per sec...
here are some specifications of the tranny... Gear Ratio: High Gear = Output/Input 59.1 drill 17.5 atwood Low Gear = Output/Input 206.8 drill 61.1 atwood Torque(tranny)=Torque(motors)*Gear Ratio * Efficiency of Gearbox T(in lb) 3172 low gear T(in lb) 906 high gear |
#11
our robot (cims and drills), goes 9.5 ft/s...i believe the ratio is 4:1...
#12
Yeah we tried doing some theoretical calculations, but thoes we wrong. Holonomic was unpredictable to say the least.
#13
3172 inch-lbs is as much torque as some cars have. I don't think your bot has as much torque as a car (That would be pretty cool though, wouldn't it )Cory |
#14
the torque title says "efficiency of the gearbox" the calculation was done right... it was checked by 3 engineers... so the transmission itself has torque of 3172... but i dont believe our robot has that much torque... if we did then we would be pushing around almost every single bot... ![]() |
#15
dont know the gear ratio but we make it from one side of the feild to the other in 6 seconds of less
| 2 fast 2 furious mocking picture :) | miketwalker | Chit-Chat | 7 | 06-18-2003 09:28 PM |
| How fast is fast to get on the hill? | ianbbat | General Forum | 76 | 03-09-2003 08:05 PM |
| need help fast!!! Hubless 1/4 pitch sprockets | Travis Covington | General Forum | 6 | 02-03-2003 05:44 PM |
| How fast? | archiver | 2001 | 4 | 06-23-2002 10:59 PM |
| How fast is the torque motor? | archiver | 2001 | 3 | 06-23-2002 09:55 PM |
