Go to Post Admiring the new chassis: "Oooo, nerd bling!" - Rick TYler [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 11-24-2004, 04:12 PM
rmmlg's Avatar
rmmlg rmmlg is offline
#0900 (Infinity)
rmmlg is on a distinguished road
Inventor to AutoCAD
We just got AutoCAD from FIRST (as I'm sure all the rest of you have too) and I became rather proficient with Inventor last year. I have used AutoCAD 2002 in Mechanical Drawing class in order to model a house. I like many things about AutoCAD better than Inventor (namely the command line) so I would like to switch over. I noticed that AutoCAD doesn't appear to have parts and assemblies like Inventor does, but instead has layers (I'm assuming that layers are analagous to ipt files in some way). Does anyone have suggestions for switching from Inventor to AutoCAD?
Ryan
Team 900 (Infinity)
Unread 11-24-2004, 06:15 PM
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: Inventor to AutoCAD
Fine, but AutoCAD and Inventor are intended for different things. There is no Inventor Architectural; once you realize that they serve different purposes, the reason for this becomes obvious.
Layers can be analogous to parts, if you happen to design things that way, but certainly that's not valid in general. Inventor is based upon assemblies of 3D solid models; AutoCAD is typically used for orthographic projections and planar layouts--nobody in their right mind uses AutoCAD's 3D mode for actual design work (it exists to simplify export of AutoCAD data into other, 3D-based programs). AutoCAD simply isn't designed to accomodate engineering data for parts themselves (mass, volume, material, etc.) [Edit: There are ways, but they are very rudimentary...try setting regions, and getting the enclosed area, then multiplying by the thickness and density--clearly this won't work most of the time], nor is it particularly well-suited to parametric modelling (AutoCAD's associative dimensions are a pale shadow--and even Inventor isn't great for this).
Don't?
If you really want to use AutoCAD's 3D mode, but still retain some sort of Inventor capability (and I assume you do, otherwise, why would you ask how to make the switch, instead of just doing it, and donating your 25+ licences to another worthy FIRST team), you can export to some convienient format, and import it into the other program. I've never tried this, but I should hope that both support 3D .dxf files. Inventor may not be able to read and assemble these, though.
Actually, if you're looking to make engineering drawings, AutoCAD has a better interface for complex tasks, but at the cost of all of the parametric information. (I like drawings that try to update themselves when the model changes, and you should too!*) If it's just a quick drawing, do it in Inventor by choosing your sketch dimensions carefully, then creating an .idw file with the required views and dimensions. It can be much, much faster than going through AutoCAD.
*Except when their geometry fails to resolve. Then it's a pain.
Unread 11-24-2004, 07:45 PM
sanddrag sanddrag is offline
back to school ;-)
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I know it isn't provided in the KOP but Solidworks is a quite lovely program that strongly rivals Inventor.
Support Team 696 on DonorsChoose!
Unread 11-24-2004, 11:10 PM
Rookie Year: 1999
And Pro/E beats them both up and steals their lunch money. Actually, Solidworks is getting better, though Inventor is considered very low-end (but if you don't have to pay for it...).
(But Pro/E has some internal issues...it needs to go see a guidance counsellor.)
Unread 11-28-2004, 11:42 PM
rmmlg's Avatar
#0900 (Infinity)
So is AutoCAD more an architectural software and Inventor more an engineering software? Like, can AutoCAD be used only really for architectural stuff?
Ryan
Team 900 (Infinity)
Unread 11-29-2004, 11:43 AM
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
No, AutoCAD can be (and is) used for many different kinds of work, including such things as architectural, mapping, electrical and mechanical design and documentation. What is isn't is a true 3D or solids design application, which Inventor, ProE and Solidworks are. AutoCAD is still well-suited for many 2D applications, however.
Pete Kieselbach
Unread 12-14-2004, 10:21 AM
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
And 3D. I use it over Inventor every time. Yeah, I know, Inventor has parametric modeling. But when you already know the dimensions of the item that you are drawing, then you don't need parametric modeling. I have used AutoCAD 2002 to model the 2004 robot, as well as seen an extremely detailed drawing of the 2003 Robot (both in 3D.)
It's not that hard to use, you just need to get used to the different commands needed to operate in 3D.
Okay, go ahead, tell me where I'm wrong ~:-)>.
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 12-14-2004, 01:04 PM
Rookie Year: 1999
If you have to know all of the dimensions already, it can hardly be considered a 3D design tool. If you just want to have a model, and never want to make any substantial changes to it (without extreme effort), AutoCAD is fine, and so is 3D Studio Max; otherwise, use something else.
Unread 12-14-2004, 02:48 PM
Unsung FIRST Hero
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Rookie Year: 1996
Guys,
I use Autocad for 3D all the time. It allows me to draw up a room add speakers and aim them, position accoustic materials and view the finished room without having to build it. Granted, I am not designing new parts for production, Mechanical Desktop and Autodesk's other products are more suited for that. ACAD does a nice job of getting your thoughts on paper, documenting as built structures and devices, calculating cable run lengths, conduit needs and plotting all of the above on paper. It is a powerful tool, don't sell it short.
I once used ACAD 3D to model the intersection of our satellite receive path in relation to O'Hare Airport 27 Left runway glide slope. This gave me the proof I needed that approach radars were getting into our satellite signals.
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
Unread 12-14-2004, 03:15 PM
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom Send a message via Skype™ to Stu Bloom
Originally Posted by Al Skierkiewicz
Guys,
I am very impressed Al. Must be that Bradley education (My daughter is a sophomore there now).
I agree that AutoCad has its uses, however I much prefer the parametric solid modelers (I have used about 5 different ones over the past 10 years, and 8 or 9 different CAD programs total over the past 20 years).
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 12-14-2004, 08:26 PM
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Send a message via ICQ to Tytus Gerrish Send a message via AIM to Tytus Gerrish Send a message via MSN to Tytus Gerrish Send a message via Yahoo to Tytus Gerrish Send a message via Skype™ to Tytus Gerrish
i can'r satnd using inventor because of the lack of the comand line. in mechanical desktop there is a model database of fasteners and everything you may need. layers are great too. and with express tools you cna download new tools for autocad. like a recent one i downloaded was helix with i can draw screws and fan blades and sprinfs snd such with.
I tried inventor and hated it because its such a blasted hastle to click on a button for everyting not to mention its realy hard to model on it.
So I Vote
AutoCad
tytusg@gmail.com
Keep It Simple Stupid
WWW.YOUTUBE.COM/TYTUSG
Autocad error?!?! Adam Y. Inventor 9 11-18-2004 10:04 AM
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 08-30-2004 10:06 PM
Redimensioning in AutoCAD indieFan Inventor 5 01-08-2004 03:55 PM
AutoCAD Viewer Gadget470 OCCRA 2 09-25-2002 02:19 AM
AutoCAD, Inventor, or Other D.J. Fluck General Forum 23 12-31-2001 07:59 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
