Go to Post Capability and willingness are two very different things. Anybody can dance, though you could spend your lifetime unsuccessfully trying to convince them of that. - Mr. Pockets [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 03-20-2002, 03:30 PM
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Rookie Year: 2000
Dan 550 is on a distinguished road
Broken Robot Controller
I have a dillema here. This dillema is a half broken robot controller -- it won't accept user code. What do I do to get this fixed? Can it be exchanged for another at J&J? I don't know why in the heck I was just told this, but our programming ninnies apparently recieved it broken. It does function in the pre-loaded code, so what do I do?
Unread 03-20-2002, 04:17 PM
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
Are you sure it's broken? Many computers have trouble with their COM ports, are you sure it doesn't work on any computer? Are you sure you are using the right port? Did you set the jumper correctly? Did you have the Operator Interface hooked up (and receiving a signal) when you tried to download code? There are so many pitfalls in programming the controller, so make sure that it really is broken before you have to put down a $1000 deposit at the regional.
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 03-20-2002, 05:58 PM
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
yeah, we had a huge problem with a com port on our laptop, so if you see a kid walking around with a laptop and the docking tray, that's me.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 03-20-2002, 06:19 PM
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Yeah, sounds like maybe the jumper isn't set to the USER position.
Unread 03-20-2002, 07:32 PM
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
Re: Broken Robot Controller
More than likely, if it will run the default code, it's not broken.
What exactly do you mean when you say "it won't accept user code"?
Does it say "BASIC Stamp not found"? If so, the most likely problem is that the com port is being used by another program (or the system) on your computer, or there's no power to RC, or you have a bad programming cable, etc.
Does it download the program, and then just sit there with the BASIC Run Error light lit? If so, you could simply need to reset the RC after downloading the program. Or you may have a program error. Be sure your program is reading the same number of data bytes in the SERIN command as you initialized the master microprocessor to send you. (Read the comments in the default program beginning at "DEFINE CONSTANTS FOR INITIALIZATION" if you don't understand what I'm talking about.) The BASIC Run Error will also happen if your program manages to not come back to read more data at the SERIN command. (Or if it's not doing it often enough.)
Could you post your program, and maybe someone here can help with debugging your code?
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 03-23-2002, 07:31 PM
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
If I am not mistaken, you can actually download your program into both the user and default slots. In fact, Innovation FIRST recommends this (or at least they did last year) because they has a 1 in 10,000 chance of forgetting the USER program. This way when they happened you could just switch the jumper and rock and roll. I do not know if they have fixed this issue.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
Unread 03-23-2002, 09:11 PM
Mark Hamilton's Avatar
Mark Hamilton Mark Hamilton is offline
Belphegor made me do it.
#0108 (SigmaC@t)
Mark Hamilton will become famous soon enough
Send a message via ICQ to Mark Hamilton Send a message via AIM to Mark Hamilton
I would suggest checking all the user jumper, as well as making sure the connector has not been damaged. Before getting a new rc, try using a different computer, or if possible ue last years rc with the same computer + code. Be sure you try all possiblities before sending your rc back to innovation first.
Retired member of Team 108
How much planning goes into your robot? Jnadke General Forum 41 01-29-2006 08:29 PM
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 03-19-2003 12:30 PM
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 06-24-2002 03:19 AM
WASH Palm scouting at the Championship Mike Soukup Scouting 2 04-19-2002 02:14 PM
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 11-26-2001 08:39 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
