For our previous robots, we've been implementing variable speed for the drive motors by using the wheel on the player one joystick. Since we took a break from FIRST last year, we did not have a chance to convert our pbasic code for the variable speed to C. When we tried, the "robot" (platform with wheels) did not follow the code at all. What happened was when p1_y became greater than 147, p1_y, pwm13, pwm 15, and p1_x all became 127 no matter where the joystick was positioned. The same happened when p1_y became less than 107. Is the algorithm to calculated the new p1_y too complex?
Could someone look at our interpretation of the code and help us find our problem? Any help would be much appreciated, thanks! Previous PBasic Code: minfwd con c127+5 minbak con c127-5 c2k con 2000 c2kc254 con c2k+c254 XYAdjust: Gosub WAdj_y Gosub WAdj_x return WAdj_y: if p1_y => minfwd then yForward if p1_y <= minbak then yReverse p1_y=c127 'yNeutral return yForward: p1_y = (p1_wheel)*(p1_y-c127)/c254+c127 max c254 return yReverse: p1_y = c127-((p1_wheel)*(c127-p1_y)/c254) return WAdj_x: if p1_x => minfwd then xForward if p1_x <= minbak then xReverse p1_x=c127 'yNeutral return xForward: p1_x = (p1_wheel)*(p1_x-c127)/c254+c127 max c254 return xReverse: p1_x = c127-((p1_wheel)*(c127-p1_x)/c254) return PWM15 = (c2k + p1_y - p1_x + 127) Min c2k Max c2kc254 - c2k PWM13 = (c2k + p1_y + p1_x - 127) Min c2k Max c2kc254 - c2k C Code placed in user_routines.c: unsigned char direction = 0; unsigned char p1_top_last = 0; if (p1_y >= 147) p1_y = ((p1_wheel)*(p1_y - 127)/254) + 127; else if (p1_y <= 107) p1_y = 127 - ((p1_wheel)*(127 - p1_y)/254); else p1_y = 127; if (p1_x >= 147) p1_x = ((p1_wheel)*(p1_x - 127)/254) + 127; else if (p1_x <= 107) p1_x = 127 - ((p1_wheel)*(127 - p1_x)/254); else p1_x = 127; pwm13 =Limit_Mix(2000 + p1_y + p1_x - 127); pwm15 = Limit_Mix(2000 + p1_y - p1_x + 127); |
Re: Program for variable speed
You need to either a) force floating point arithmetic by dividing by 254.0, or b) scale the intermediate calculations up by multiplying by a constant (e.g. 256) first and dividing by the same constant just before adding the 127. |
and for what its worth, sticking with integer division is almost always the best choice... floating point division on this processor is surprisingly slow, having no fpu.
Matt |
So would this be the same if I just added parenthesis and changed the formula to this: if (p1_y >= 147) p1_y = ((p1_wheel*(p1_y - 127))/254) + 127; or is this what you were trying to say? if (p1_y >= 147) p1_y = ((p1_wheel*(p1_y - 127)*254)/(254*254)) + 127; Thanks, I shall try these out! |
That was one of our thoughts about the problem....that it was doing the calculation and somehow losing the number. We didn't know how to solve this problem though. Thanks for the suggestion. We'll try creating new 16-bit variables and try this again. |
| initialization program and speed controllers | rosebud | Programming | 15 | 10-05-2004 02:35 AM |
| PID control loops - closed loop feedback | KenWittlief | Technical Discussion | 56 | 04-26-2004 08:27 PM |
| how to add steps in the provided encoder program for the edu | Zaramel2002 | Programming | 3 | 02-11-2004 07:35 AM |
| Fried program slots? | Jeff Waegelin | Programming | 18 | 03-19-2003 05:08 PM |
| Ahh! Program trick confusing! | archiver | 2001 | 9 | 06-24-2002 01:26 AM |
