Go to Post I will test first 'cause you cannot learn unless you break something first! - Andy Brockway [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 01-19-2005, 04:43 PM
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Spring Return Pistons' Legality
Are single-action spring return pistons legal for use on robots this year? Our pneumatics leader is unsure and I have yet to find a ruling against it. Thanks in advance.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 01-19-2005, 07:08 PM
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Re: Spring Return Pistons' Legality
i have asked through the FIRST Q & A board specific pneumatic questions
all their responses say to refer to R90 and the flow chart
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 01-19-2005, 07:21 PM
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
The only pistons that may be used are those available from the kit, and identical models (see Rule <R90>). These are documented on Page 19 of the 2005 Pneumatidcs Manual. That list does not include single-action spring return pistons. So, I would think the answer would have to be "no."
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 01-19-2005, 07:25 PM
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Originally Posted by FRC 2005 Manual, SECTION 5 THE ROBOT
<R90> There is no limit to the number of solenoid valves, air cylinders, pressure regulators, and connecting fittings you may use on your robot. They must, however, be “off the shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi. Besides the “free” pneumatic components listed on the Pneumatic Components Order form, you may purchase additional air cylinders or rotary actuators, however, they must be identical to those listed on the Pneumatic Components Order form , and obtained from a Bimba or Parker Hannifan distributor.
Please refer to the highlighted parts, pretty much its all ready in plain english right there. If the cylinder you want to use is on the pneumatics order form (last page of the 2005 FRC Pneumatics manual) then you can buy it and use it, if its nto there, its not legal to use.
-Michael Dessingue
Adaptative Spring - Driving constraint Daniel_H Inventor 2 11-03-2004 01:33 PM
NEW Spring Off Season in NJ Wayne C. Off-Season Events 25 06-11-2004 09:21 AM
Spring Compression in Inventor 6? psychoCHIPMUNKK Inventor 1 05-23-2004 12:44 PM
Legality of Spring Loaded Pistons Yan Wang Pneumatics 13 02-19-2004 04:20 PM
Bosch Drill Motor Clutch Spring Dimensions?? aaronbr28040 Motors 3 02-18-2004 06:52 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
