Go to Post If I run into some of your team's student coaches/drivers on the field of battle someday, I still might ask 'em what they're doing after high school. :) - Ken Patton [more]
Go Back   Chief Delphi > Technical > Control System > IFI Control System
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Cross the Road Electronics
ADVERTISEMENT
Unread 01-24-2005, 12:25 PM
Team ICE #1611 Team ICE #1611 is offline
Team ICE #1611 is an unknown quantity at this point
We need help with joystick control
This past Saturday our robot came to life when we swithched it on for the first time. We all thought it was great but there was one problem it worked with two joysticks and we only want to use one. Its working on PWM's 1 and 2 and 13-16 PWM's dont work. Any suggestions on how to get it to work with one joystick?
Unread 01-24-2005, 12:44 PM
Charly's Avatar
Charly Charly is offline
AKA: Ricardo Martins
#0714 (Super Panthers)
Team Role: Electrical
Charly is an unknown quantity at this point
Send a message via AIM to Charly
Re: We need help with joystick control
Is your robot 2WD, 4WD, 6WD?
Team 714 Robotic Design Captain/Electrician
Winners of the 2004 New Jersey Regional Chairman's Award!
Competitions we'll be attending in 2005: NJ Regional, Florida Regional, Championships!
Unread 01-24-2005, 01:29 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
If you're using the default software with camera support, notice that the comments do not accurately describe the code itself. The pwm outputs for single joystick control are on pwm11 and pwm12. (I might be misremembering, so check it out for yourself.)
Unread 01-24-2005, 02:27 PM
we are using 2WD
Unread 01-24-2005, 02:57 PM
vtrehan's Avatar
vtrehan vtrehan is offline
Mentor - Controls & Programming
AKA: Vivek Trehan
FRC #1241 (Theory6)
vtrehan is on a distinguished road
Send a message via Yahoo to vtrehan
Which version of the FRC code are you currently using? If it is the version without the camera mode then idealy a problem should not occur (unless its some faulty wiring).
If you are using the version with the camera operation code, then I would recommend you first try out the non-camera mode, then after you are certain of your basic wiring/assembly, you can move on to the higher stuff.
The non-camera default code is driven by one joystick, and you should use PWM 13 (for right drive motor) and 15 (for left drive motor), as you said you have 2 wheel drive.
Please PM me if you need detailed assistance
2006-GM Industrial Design Award - Greater Toronto Super Regional
2006-Engineering Inspiration Award - Arizona Regional
2006-Regional Finalist - Arizona Regional
2005-Best Defensive Robot - Wonderland Off-Season
2005-Regional Chairman's Winners - Greater Toronto Regional
2005-Regional Champions - Waterloo (Thanks 68 and 1305)
2005-Best Website - Greater Toronto Regional
2005-Team Spirit Award - Waterloo
2005-Entreprenuership Award - Waterloo
2004-Rookie All-Star award - Great Lakes Regional
2004-Rookie Highest Seed - Greater Toronto Regional
2004-Rookie All-Star award - Greater Toronto Regional
2004-Team Spirit award - Greater Toronto Regional
2004-Team Spirit award - National Championship
Single joystick control problem Mr. Van Programming 7 11-23-2004 08:10 AM
One Joystick Control KWalsh Programming 4 02-24-2004 04:53 PM
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 02-20-2004 04:00 PM
how do i control a piston with a joystick Ryan Foley Programming 2 05-27-2003 04:13 PM
robot goes haywire with the one joystick default code Miles Programming 7 01-24-2003 01:58 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
