Problem with MPLAB
how do you export MVS projects as hex files
Re: Problem with MPLAB
In the toolbar:
Project -> Build All or Ctrl+F10 if that does not work, then make sure that mcc18 is inside.. By going to (in the toolbar): Project -> Select Language Toolsuite... |
Yah i tryed that still dosen't work. when i go to build it says:
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F452 "user_SerialDrv.c" -fo="user_SerialDrv.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- This version of the compiler supports only the PIC18F8520 processor. Halting build on first failure as requested. BUILD FAILED: Sat Jan 29 15:21:31 2005 Help please |
Try re-installing mcc18,
or if that does not work, than perhaps you have the wrong PIC setup in the workspace by going to "Configure -> Select Device" and set it to PIC18F8520 Last edited by AIBob : 01-29-2005 at 03:24 PM. |
Ok I did all that now it says:
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "user_SerialDrv.c" -fo="user_SerialDrv.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- C:\mcc18\h\p18f8520.h:169:Error [1109] type mismatch in redeclaration of 'PORTBbits' C:\mcc18\h\p18f8520.h:201:Error [1109] type mismatch in redeclaration of 'PORTCbits' Halting build on first failure as requested. BUILD FAILED: Wed Feb 02 16:20:53 2005 |
http://www.chiefdelphi.com/forums/sh...690#post330690 Last edited by Mark McLeod : 02-02-2005 at 08:49 PM. |
| Programming Problem: Extremely Frustrating | chantilly_team | Programming | 19 | 02-12-2005 10:00 PM |
| MPLAB Variable Simulator? | Chris_Elston | Programming | 3 | 02-18-2004 11:08 AM |
| using the MPLAB IDE MPLAB SIM simulator | WizardOfAz | Programming | 1 | 11-03-2003 12:24 AM |
| The problem with scouting... | archiver | 2001 | 10 | 06-23-2002 10:49 PM |
| Major problem with chipphua motors | aka Scott White | Motors | 18 | 03-19-2002 06:44 PM |
