Go to Post Build a robot that isn't 119.999999 lbs - Tubatroopa [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Team 221 LLC
ADVERTISEMENT
Unread 02-01-2005, 09:41 PM
cloudago cloudago is offline
cloudago is an unknown quantity at this point
Send a message via AIM to cloudago
MPLink Error
We ran into a problem when we tried defining unsigned chars in a header file and running into a Linker error that claimed that a variable had multiple definitions.
This is what we have in the header file which causes the error:
long int KP_P = 5;
This is the error given by the Linker:
Error - symbol 'KP_P' has multiple definitions.
This source code does not cause an error:
#define KP_P (5)
Declaring the variable as a long int in the *.c file does not cause any errors, it is only in the header file that it causes the error.
Has anyone run into this error or is it a bug in the Linker?
Unread 02-01-2005, 10:00 PM
probizzle's Avatar
probizzle probizzle is offline
AKA: Prabhas Pokharel
#0639 (Code Red)
probizzle will become famous soon enoughprobizzle will become famous soon enough
Send a message via AIM to probizzle
Re: MPLink Error
It is not a bug in the linker.
When you declare a long int in the header file, every time a .c includes this header file, space will be allocated for KP_P. Even if you have the #ifndef __header_file_name_h_ #define __header_file_name_h_ at the top of the file.
Here is the solution:
declare lont int KP_P in a .c file.
However, also
add
extern long int KP_P;
in the header file.
Now, if you include this header file, you should be able to use KP_P.
Another comment:
the define doesn't show an error, because it is essentially a copy paste operation, and the compiler is smart enough to figure it out.
Code Red Team 639 Winners of the 2005 FingerLakes Regional with 191 and 494.
http://pset.deu83.com << my baby
http://www.setgame.com/set/ << it's mother
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: MPLink Error
This is not a bug. KP_P is defined somewhere else. Either fiond out where or change the variable name.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
MPLab build error Derek t Programming 7 01-17-2005 08:33 AM
error - Invalid 18f8520 header file! vtrehan Programming 2 11-16-2004 07:31 AM
Confusing Compiler Error UrsaMNet Programming 2 10-28-2004 01:32 PM
PHP and Wiki Error Venkatesh Website Design/Showcase 2 07-24-2004 02:51 PM
Linker Error Max Lobovsky Programming 4 05-27-2004 07:16 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
