Camera lens not straight?
Has anyone noticed that the camera doesn't point exactly at the target even though the pan.servo is reading 128.???
It's not any adjustment in our mounting either. The camera is responsible for centering the centroid in the field of view regardless of how the servo is mounted. The only way it can point straight is if we shim the lens about 15 degrees. |
Re: Camera lens not straight?
T 80 120 60 100 100 140 32 158 135 131 clearly shows the mid mass of X is @ 80 which is 1/2 of the width of 159. Changed both the camera moduleand UbiCom board.... same problem.. WHAT's UP WITH THAT ???? |
Not sure what you mean here.. our camera won't always look like its pointing at something, but it will still have a lock on it and track it sucessfully.. Is the red light steady on the front of the camera?
| Scripting Setup and the Camera + Serial Port Drivers | CJO | Programming | 22 | 01-11-2006 04:42 PM |
| Unresponsive camera | neilsonster | Programming | 9 | 02-17-2005 07:51 AM |
| Kevin Watson's Kick-off Demo Code! | Mr. Lim | Programming | 27 | 01-22-2005 02:38 AM |
| Game Field Camera Calibration | Matthew_H | Regional Competitions | 2 | 01-15-2005 10:09 PM |
| CMUCam2 Camera Code - Are important parts commented out? | Mr. Lim | Programming | 4 | 01-14-2005 11:11 AM |
