Go to Post There will inevitably be enough unintentional failure in any endeavor we take on that adding intentional failure on top of that seems unnecessary. - Jared Russell [more]
Unread 02-05-2005, 08:28 AM
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
default code vs. 2.4
hi,
we tried using the 2.4 default code, which supports the cmucam. The robot didn't respond to the joysticks or anything. Yet, the bot worked fine (the base of the bot we have finished so far) with vs. 2.2 of the default code (completely unmodified!!!). any suggestions? the electrical wiring has stayed the same. is there a newer vs. of ifi loader I need? I know the 2.4 code supports the cmucam, we didn't have that hooked up. but it shouldn't need it hooked up right? appreciate your help, thanks,
Stephen
Unread 02-05-2005, 11:02 AM
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: default code vs. 2.4
You can turn the camera off in 2.4 by opening the project and doing Project->Build Options->Project.
Locate the MPLAB C18 tab in the dialog that pops up and click it. Just click the '_USE_CMU_CAMERA' (or whatever it's called. It's obvious) and hit "Remove." Also make sure hte "Use alternate settings" is unchecked. You'll be warned by the compiler that there's a type mismatch with the printfs, but it doesn't matter. I think...
Unread 02-05-2005, 05:02 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If you're using single-joystick drive, the proper pwm outputs changed between version 2.2 and 2.4 of the default code. Version 2.2 uses pwms 13-16. Version 2.4 uses pwm11 and pwm12.
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 01-31-2005 09:28 PM
Victors, Default code, & joystick configuration Vermatitis Control System 4 01-27-2005 03:01 PM
Default Code and printf WilsonDJ00 Programming 2 01-22-2005 03:39 PM
heres the code. y this not working omega Programming 16 03-31-2004 02:18 PM
Is default code already loaded? quickie25 Electrical 8 02-19-2004 09:51 PM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
