Go to Post The theory is we'd lose a paper list but we haven't lost a student yet. - Peter Matteson [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Team 221 LLC
ADVERTISEMENT
Unread 02-14-2005, 08:49 PM
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
An inspired alumnus
AKA: Jamie Bliss
no team (previously 904 (D-cubed) and 1227 (Techno-Gremlins))
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Send a message via ICQ to Astronouth7303 Send a message via AIM to Astronouth7303 Send a message via MSN to Astronouth7303 Send a message via Yahoo to Astronouth7303
Syntax Error: externs, structs, and macros
Here's the thing: I'm getting a syntax error in 2 seperate lines that are probably related. I have narrowed it down to the point that I know that it is not the next or previous line.
They are:
Code:
BEGIN_MOTOR_LIST(motor_list)
	MOTOR(STRAIGHT,	LeftDrive,	OI_Left,	0,	0,	 0,	 0,	0,	254,	254) //ME! ME!
END_MOTOR_LIST
Code:
REF_MOTOR_LIST(motor_list);
Here are the dependencies needed to get this:
Code:
#ifdef _MOTORS_H_
#define _MOTORS_H_
typedef enum {NONE,STRAIGHT,POSITION,FISHER} MotorType;
struct motors
	enum Motor type;
	char* pwm;
	char* oi;
	char pot;
	char pot_min;
	char pot_max;
	char pot_center;
	char pwm_min;
	char pwm_max;
	char pwm_change;
#define BEGIN_MOTOR_LIST(name) struct motors rom name[] = {
#define END_MOTOR_LIST                   {NONE, 0, 0, 0, 0, 0, 0, 0, 0} };
#define REF_MOTOR_LIST(name) extern struct motors name[]
#define PTR_MOTOR_LIST(name) struct motors *name
#define MOTOR(type,pwm,oi,pot,pot_min,pot_max,pot_center,pwm_min,pwm_max,pwm_change) {type, &pwm, &oi, pot, pot_min, pot_max, pot_center, pwm_min, pwm_max, pwm_change },
void DoMotors(PTR_MOTOR_LIST(motorlist));
#endif
Code:
char LeftDrive, RightDrive, E2;
#define OI_Left  p1_y
(unfortunately, it inserted random spaces)
Enlightenment?
Unread 02-14-2005, 09:54 PM
Orborde Orborde is offline
FRC #1747
Orborde has a spectacular aura aboutOrborde has a spectacular aura about
Send a message via AIM to Orborde
Re: Syntax Error: externs, structs, and macros
Code:
#define MOTOR(type,pwm,oi,pot,pot_min,pot_max,pot_center,p  wm_min,pwm_max,pwm_change) {type, &pwm, &oi, pot, pot_min, pot_max, pot_center, pwm_min, pwm_max, pwm_change },
Might it be the marked bit?
Unread 02-14-2005, 11:30 PM
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
I didn't spot anything wrong off-hand (other than the space noted by the previous poster, but I'm guessing that was a copy/paste problem?). Something you might try to narrow down the problem is pre-processing the C file to see how your macros worked out. There should be a cpp18.exe as part of the MCC18 package - this is the C preprocessor. Just run:
Code:
cpp18 {filename}.c -I{path to MCC18 include directory} > {filename}.pre
and it will spit the preprocessed file out to {filename}.pre. That might yield some clues.
Unread 02-16-2005, 02:39 PM
An inspired alumnus
AKA: Jamie Bliss
Originally Posted by Orborde
Code:
Nope. That's just from the post. Try as I did, I couldn't get rid of it. But it doesn't exist in the file.
Code:
Cool! Thanks! I'll try that!
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
