servos
how much weight can the servos take on them
how much can they move |
Re: servos
Re: servos
do you thingk they are strong enough to hold back 7 kg
iam making a catapult and going to use it as a trigger.going to use a servo i have that is the same that came in the kit |
Re: servos
No, but it might (and I say might) be strong enough to pull out a small pin that is holding the 7 kg.
Re: servos
You could mount the pin such that it is supported on some rollers or bearings so that there is only a very small force required to pull it out.
Re: servos
thanks guys i will consider it
i might use an old fiser price that i have ill put a pic of it up when iam done hoe full it will work |
| Hooking up 2 Servos | kutty18 | Programming | 7 | 02-04-2005 08:26 AM |
| questions about the servos | Alex Golec | Motors | 1 | 01-23-2005 07:05 PM |
| using older servos | pryoplasm | Kit & Additional Hardware | 4 | 01-24-2004 07:22 PM |
| Need help in creating program to use servo's to shift drive | archiver | 2001 | 19 | 06-23-2002 11:35 PM |
| servos, chapulas, cylinders and Skyway...in other words... | Jessica Boucher | Motors | 7 | 01-14-2002 06:36 PM |
