Go to Post if sleep is essential, then yeah, I'm in trouble. - Eria4044 [more]
  #31   Spotlight this post!
Unread 04-11-2005, 04:18 PM
Rod's Avatar
Rod Rod is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
Re: pic: One Tough Train
Originally Posted by Matt Reiland
Wow, that is an incredible amount of weight to be putting into the base!! 3 rows of solid steel bar plus what looks to be large blocks of aluminum to hold them? Add in the weight of about 12ft of chain and you should be at about 75 lbs.
Have you considered aluminum tube maybe 1/8" wall 1" dia?
All the 1/4" in the base is a little heavy for a first robot, you could build the whole thing out of 80/20 and still be a bunch lighter. Just my 2 cents but I have yet to see a robot that has that much weight to burn unless you plan on having no manipulator.?
It does look nice and clean in inventor, great job on that.
The weight is 68 Lbs. That is right about where we want it.
-Rod-
Team 662
Colorado Springs, CO
  #32   Spotlight this post!
Unread 04-11-2005, 04:59 PM
Conor Ryan Conor Ryan is offline
Back to Financial Engineering
FRC #9998 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Originally Posted by Tristan Lall
That looks interesting....
I mostly concur with sanddrag, except for that sprocket thing.
A couple of years ago, in 2003, Woburn used those same little sprockets, and promptly broke something like 13 #25 chains over the course of three events. Since there's no such thing as too much horsepower, the chain simply wasn't up to what we demanded of it. (It undergoes higher stresses as sprocket radius decreases.) ....
can't this all simply be solved by replacing the chain system with timing belts? Cars use them and put them under alot more stress than we ever will, no to mention are quite a bit litter than chains.
  #33   Spotlight this post!
Unread 04-11-2005, 06:22 PM
sanddrag sanddrag is offline
On to my 15th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
No, If you break a chain, you are sure as heck going to break a timing belt, unless it slips first which would be almost as bad.
Purchase Cree LED Bulbs from the Team 696 Online Store
  #34   Spotlight this post!
Unread 04-11-2005, 09:33 PM
Rod's Avatar
Rod Rod is offline
Mentor
This is our drive train this year, it was designed in preseason and modified for this year's game. And yes we always use #35 chain in our drive trains.
ID:	3281  Click image for larger version
Name:	Frame Assembly10.jpg
ID:	3282  Click image for larger version
Name:	Frame Assembly11.jpg
-Rod-
Team 662
pic: Team 11 Drive Train Team S.Nickens Robot Showcase 2 02-22-2005 02:13 AM
pic: 1493 Drive Train 1 Dan-o Robot Showcase 15 02-17-2005 02:59 PM
pic: Next Years Drive Train CD47-Bot Extra Discussion 15 06-11-2003 09:32 PM
what's your most important drive train advice? Ken Leung Technical Discussion 42 01-07-2003 09:58 AM
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 01-29-2002 12:32 PM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
