Go to Post Quitting when faced with adversity is not the answer. We have to figure out a solution within the constrainsts applied. - Rob [more]
Go Back   Chief Delphi > Technical > intelitek easyC/REC information > easyC for FRC
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 01-13-2006, 03:13 PM
chadbarbe chadbarbe is offline
FRC #1450
chadbarbe is an unknown quantity at this point
Limit switch in easy c?
I've only messed around with easy c a couple of times and i was able to get a 2 motor tank drive system up and running in no time... i love it! however, I'd like to get my limit switches working to prevent an arm motor from going too far (either up or down)... I know how to do this by handing coding in MP lab but I am not sure how to do it within the constraints of Easy C. Any suggestions?
CHAD
Unread 01-13-2006, 03:19 PM
MikeL303 MikeL303 is offline
1403
FRC #1403 (Cougar Robotics)
MikeL303 has a reputation beyond reputeMikeL303 has a reputation beyond reputeMikeL303 has a reputation beyond reputeMikeL303 has a reputation beyond reputeMikeL303 has a reputation beyond reputeMikeL303 has a reputation beyond reputeMikeL303 has a reputation beyond reputeMikeL303 has a reputation beyond reputeMikeL303 has a reputation beyond reputeMikeL303 has a reputation beyond reputeMikeL303 has a reputation beyond repute
Re: Limit switch in easy c?
well i don't know how different the easy c from vex is to FRC but i did make a code for two limit switches on one motor.
if you want the code email me at michaelleicht@gmail.com and i will get you that code for the limit switch.
Team 303 (2003-2007)-Student-Won FIRST Scholarship to Daniel Webster College
Team 42 (2007-2008)-College Mentor
Team 2342(2008-2011)-College Mentor
Team 1403 (2011- )- Mentor
Unread 01-13-2006, 03:57 PM
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Thumbs up Re: Limit switch in easy c?
1. Map Analog to OI Input to a variable
2. Map PWM Control to a variable
3. Make a few "IF" statements
4. Make a few Assignments
Thats pretty much the gist of it. We will be releasing
samples in the future on how to perform these activities.
Also, EasyC for FRC and VEX work pretty much the
same way for driver control.
Unread 01-13-2006, 04:00 PM
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
CHAD
All you need to do is to be able to tell when the limit switch was depressed at the same time that the motor is trying to run in that direction. That way, you will only limit the direction of the motor in that direction, while still allowing for it to go in the other direction.
Here is how this sample arm/elevator is set up. There is an upper and a lower limit switch. The PWM signal for moving the arm up must be between 127 and 255. The PWM signal for moving the arm down will be between 0 and 127. Here is a diagram of this setup:
And here is the code: (from EasyC 2.0)
Code:
#include "Main.h"
void main ( void )
      char upperlimit;
      char lowerlimit;
      unsigned char arm;
      while ( 1 )
            upperlimit = GetDigitalInput ( 1 ) ; //Upper limit Switch is plugged into I/O Port 1
            lowerlimit = GetDigitalInput ( 2 ) ; //Lower limit Switch is plugged into I/O Port 2
            arm = GetRxInput ( 1 , 1 ) ; //Arm control is coming from RX port 1, Channel 1
            if ( upperlimit == 0 && arm > 127 )
                  arm  = 127 ;
            if ( lowerlimit == 0 && arm < 127 )
                  arm  = 127 ;
            SetPWM ( 1 , arm ) ; //Set PWM port 1 to 'arm' variable
Arthur Dutra IV
Robotics Engineer, VEX Robotics, Inc.
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon
世上无难事,只怕有心人.
Unread 01-13-2006, 04:05 PM
Kingofl337's Avatar
AKA: Adam
Rookie Year: 1998
In FRC you would substitute "GetRXInput" with "GetOIAInput".
Thanks artdutra04 for the example.
Unread 01-13-2006, 05:27 PM
FRC #1450
Thanks everybody! This information was very helpful. I had forgotten that I can use the joystick value as a representation of what my PWM output will be. I was stuck because I couldn't find a way to look up what the PWM value was and didn't realize that I didn't even need it!
Unread 02-02-2006, 08:51 AM
scottmso scottmso is offline
FRC #1561 (RoboDucks)
scottmso is an unknown quantity at this point
Send a message via AIM to scottmso
Be careful not to use a while loop for this, I did that and the limit switch essentially acted as a "kill switch" for the robot
limit switches stephenthe1 Programming 28 05-11-2005 03:37 PM
How do you wire a limit switch? JMH Electrical 1 02-16-2005 04:44 PM
LEDs in switch box. ZZII 527 Electrical 5 03-06-2004 06:39 PM
sample limit switch code??? tml240 Programming 5 02-17-2004 04:13 PM
Need help with 255 Variable Joseph F Programming 18 02-26-2002 01:49 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
