Go to Post You can also always use the "Report Post" button on each post and that'll dispatch a carrier pigeon to each of our homes...or an e-mail if the carrier pigeons have taken the day off. - Madison [more]
Go Back   Chief Delphi > Technical > Control System > IFI Control System
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 01-25-2006, 05:33 PM
Vashts6583's Avatar
Vashts6583 Vashts6583 is offline
The sleepless
AKA: Rob Metzger
FRC #0007 (Team 007)
Team Role: Leadership
Vashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to all
Send a message via ICQ to Vashts6583 Send a message via AIM to Vashts6583 Send a message via MSN to Vashts6583 Send a message via Yahoo to Vashts6583
Exclamation OI Aux Fault light red
Ok. With the 2004 OI, the Aux Fault light is red whenever p1_sw_top is pressed. I've tried switching joysticks, and it is still red when the top button is pressed. I haven't changd th code for the p1_sw_top code from last year, but for some reason it is Red on this year's controller. Unfortunately, last year's controller's Port 1 interface died early on into last year's build season, and this year's interface's power port was broken two days ago, so we don't have a backup OI. Any way that I can try to either override or fix this problem?
Oh, and more info: I checked the error with Dashboard, and on the OI setting, I pressed the top button on the joystick, and the x, y, and wheel values of ports 1-3 went immediately to 0. It bothers me to no end. Help please!!
2005: Software Assistant
2006: Software Head
2007: President/Driver/Software Head/Temporary Safety Captain
//2005: Chesapeake Regional - Finalist
Life is what you do outside of FIRST. No wonder it's so short.
Unread 01-25-2006, 10:10 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Re: OI Aux Fault light red
Easy answer: your joystick's button is grounding the +5 (Aux) pin on the joystick port. +5 (Aux) is pin 1; the trigger button is pin 2. I suspect there's a short in the OI.
To work around a broken power connector, you can tether the OI to the RC and get power that way. You can also call IFI, explain your problem, and ask if they'll tell you which pin on the competition port is the power supply so you can run it untethered.
(A 2004 OI will not work with the 2006 field electronics, so you can't use it in competition.)
How many users does it take to change a Light Bulb? Matt Attallah Chit-Chat 4 09-04-2004 07:59 PM
Yellow card / Red card usage at 2004 IRI Andy Baker Rules/Strategy 53 08-01-2004 11:35 PM
program light blinks red and green JBabbie Programming 3 03-02-2004 08:19 AM
Please...no more steenkin' light! Andrew General Forum 37 04-17-2003 10:06 PM
Important info about light Jay Lundy Technical Discussion 10 04-12-2002 10:37 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
