Go to Post ALL technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function. - kmcclary [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 02-02-2006, 09:48 AM
Bruce Barber Bruce Barber is offline
FLL #1320
Bruce Barber is an unknown quantity at this point
Lightbulb Making a LabVIEW Multimeter
How do you get supported devices under DAQ Assistant function ? We have a problem with finding supported devices. What is an example of a supported device we may need for this operation ?
Unread 02-02-2006, 01:07 PM
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
AKA: FrankenMentor
FRC #0418 (LASA Robotics / Purple Haze)
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Making a Multi-meter on Labview
The DAQ Assistant supports all devices listed in the readme file for NI-DAQmx 8.0.
NI Pilot Program Teams were all given NI USB-6009 DAQ devices, which can be used very nicely for the purposes of a Voltmeter but cannot be used to measure currents directly (though an Allegro Microdevices current sensor has successfully been used by team 418 with the USB-6009 device).
-Danny
Danny Diaz
Lead Technical Mentor, FRC 418
Unread 02-09-2006, 10:44 AM
FLL #1320
-Danny
Thank you Danny but it seems we ither have not downloaded the 2 files or we have and are lost. Unfortunatly we are running a extreamly slow computer that would make a 56K connection look like a wireless one. But we are attempting to download these two files. (NIDAQ740CD1.zip [517mb] NIDAQ740CD2.zip [174mb] ) Will this help. We are (as already stated in my first post) attempting to create a Multi-meter. But it sounds like this wont work...? Is it possible to do something similar? This will help us very much. Please give us a little bit more information on what we need do download or what we need to do.
-Bruce Barber
Unread 02-09-2006, 03:31 PM
Danny Diaz's Avatar
AKA: FrankenMentor
Bruce, I think you may have me at a disadvantage - your "team affiliation" states you're affiliated with FIRST LEGO League team #1320, so I have no way of determining if you're on an NI Pilot Program team. Beyond that, there are a couple things we'll need to determine:
  1. What device are you going to use for the multimeter, i.e. how are you planning on acquiring the voltage and/or current readings? (e.g. NI USB-6009, something with an ADC, DMM with PC interface, etc...)
  2. Once you have the readings, what bus/interface do you want to use to transfer those readings into your computer? (e.g. USB, Serial, LPT, Bluetooth, IrDA, etc...)
I assume you're using the LabVIEW 8.0 Student Edition provided in your FIRST Kit of Parts this year - if so, and you plan on using a National Instruments product as your multimeter, you need to be downloading files from the following location (It's still 466MB, unfortunately):
ftp://ftp.ni.com/support/daq/pc/ni-d...0/NIDAQ800.zip
Please give me some kind of idea as to how you plan on making your multimeter, and we can discuss the best way to integrate it with LabVIEW.
-Danny
Danny Diaz
Unread 02-10-2006, 10:54 AM
FLL #1320
Re: Making a LabVIEW Multimeter
Well Danny,
Although we DO support FLL we also support FIRST ROBOTICS we have students from the middle school and other surrounding schools in our district coming and working with the Lego's. We also (as stated above) are in FIRST.
Thank you Danny for you help so far with the multimeter. But we do not NEED the LabVIEW multimeter. It was mostly a project for the students that are working with LabVIEW. We did not expect it to be this hard to create. Thank you Danny for your so far help. But this seems to be too big for our students to handle. So were going to 'nip it in the bud' so to say.
-Bruce Barber
LabVIEW Com Port Error 354.FIRST LabView and Data Acquisition 4 01-18-2006 05:43 PM
Labview problems and code problems ajsetter Programming 25 01-18-2006 04:07 PM
National Instruments LabVIEW and Data Acquisition Forum Danny Diaz National Instruments LabVIEW and Data Acquisition 1 01-16-2006 12:20 PM
COM port settings for CMUcam labview testing and programming pwilczynski Programming 1 01-15-2006 02:09 PM
National Instruments LabVIEW & Data Aquisition Forums Brandon Martus Announcements 0 11-22-2005 08:12 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
