Go to Post I think with so many facets of FIRST, success comes from learning the true meaning of teamwork through working towards a common goal. - Kristina [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 02-13-2006, 02:35 PM
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
T_Packet_Data.mx probs
I got the camera scanning and such, the only problem is that the refinment part of the code doesn't work! The camera just turns one way until it looses the atrget. I've looked at the code and can't find any obvious flaws and thought taht maybe T_Packet is different from .my. Maybe it doesn't go neg or something? Or is there just something in Kevins code I missed? I set the pan error high so it won't need the routine, but that kills the alignment code I'm working on. Any suggestion to fix the code would be great.
Unread 02-13-2006, 04:24 PM
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
Re: T_Packet_Data.mx probs
(This has been discussed in other threads, but...) You probably have your camera mounted upside down from the way Kevin's code assumes. You have (at least) two options:
  1. Invert your camera. (Turn it upside-down.)
  2. Change the PAN_ROTATION_SIGN_DEFAULT and TILT_ROTATION_SIGN_DEFAULT parameters in tracking.h.*
*Or, if you're using the "Bells and Whistles" version of the camera code, use the tracking menu to change them.
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 02-13-2006, 06:03 PM
Ryan O's Avatar
Thanks for the suggestion. Shortly after I decided to post here, I was tinkering with the code. I found by making search step equal to what it was originally equal to multiplied by negitive one, the camera operates normally
Unread 02-13-2006, 06:17 PM
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Rookie Year: 1998
That's exactly what PAN_ROTATION_SIGN_DEFAULT and TILT_ROTATION_SIGN_DEFAULT do.
Unread 02-13-2006, 11:34 PM
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Cañada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
You should consider mounting the camera such that the tilt axis extends through the camera. You'll get better tracking performance if you do. Once you've done that, start with a fresh copy of the camera code and it should just work.
-Kevin
Kevin Watson
Engineer at Space Exploration Technologies (SpaceX)
http://kevin.org
Fisher price motor gear specs archiver 2000 4 06-23-2002 10:23 PM
"Official" IRI Announcement David Kelly Off-Season Events 35 06-04-2002 05:32 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
