Go to Post darn design trade-offs! the game design committee does this to us every year! - KenWittlief [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
ADVERTISEMENT
Unread 02-14-2006, 11:28 AM
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
None #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Send a message via AIM to Chris_Elston Send a message via Yahoo to Chris_Elston
Interrupt Maximum before the RED light DEATH?
I've been hunting around for a maximum of interrrupt 1-6 on the 2006 controller and 2005 if they are different. Best I've found is Kevin's documents that say "thousand of clicks per second" on a 40 MHZ PIC chip.
Is there a spec somewhere? Or does that really depend on how much code you have?
We are using the gear teeth sensors which say they have a maximum of 6KHZ of bandwidth, but wanted to make sure we wouldn't kill our CPU if we try and spin the gears up pretty fast. I think we are running around 1176 pulses per second, and the interrupt seems to be behaving. It would be nice to know what are "true" max is before we bury the CPU.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 02-14-2006, 12:17 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Re: Interrupt Maximum before the RED light DEATH?
The PIC executes ten million instructions per second. If your interrupt service routines don't use them all up, the main program will be able to execute. Counting instructions is tedious and error-prone, but it'll give you the answer you're looking for.
A less tedious way would be to set an output pin high when you enter the interrupt service routine, then set it low as you leave. An oscilloscope on that pin will tell you how long and how often the routine runs, and will give you a reasonable indication of what fraction of the time you're spending servicing interrupts.
Unread 02-14-2006, 12:28 PM
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Sinecured Grand Poobah
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Sorry, I'm not quite getting what you're saying, and if this doesn't help, again, I apolgize, just ignore it.
From what we, team 1719, have figured out, it seems that the geartooth ticks are determined by the amount that it's low.
We have so far seemed to have no problems with our system and we haven't worried about any of this math.
Best of luck,
Paul Dennis
Unread 02-14-2006, 02:29 PM
Mark McLeod's Avatar
Itinerant Programmer
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
It does depend on your code of course and the worst case time it takes you to execute a fast loop including your maximum # of interrupts. Unless the slow loop is really bloated I doubt you'd be bound by that time, but if your time to complete a fast loop approaches slow loop speed you'll be in trouble.
When the slow loop becomes impacted you get the Red Light of Death.
You can also get an approximation by counting the number of fast loops per second with minimal interrupts, then running your interrupts at max and comparing, both times looking for the worst case.
I think we measured the streamlined camera code at a worst case of 65,000 loops per second without other interrupts.
"Everyone you will ever meet knows something you don't" - Bill Nye
Unread 02-15-2006, 12:01 AM
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
What type of output? An relay? A PWM? Don't those only update after every putdata() call, i.e. every 26.2ms?
Confused,
Robinson
'... who are you, then?'
'I am part of that power which eternally
wills evil and eternally works good.'
Goethe, Faust
Unread 02-15-2006, 05:53 AM
Software Architect
A digital output. They're directly connected to the CPU pins, and change state immediately.
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 02-10-2007 03:34 PM
Encoders and putdata theycallhimtom Programming 3 02-09-2006 06:24 PM
TTL port to a serial port on a demo board ImmortalAres Programming 16 07-09-2005 10:44 PM
How many users does it take to change a Light Bulb? Matt Attallah Chit-Chat 4 09-04-2004 07:59 PM
heres the code. y this not working omega Programming 16 03-31-2004 02:18 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
