I am having a problem with the 2005 camera code and the 2006 controller. The camera will "glitch" randomly and never recover. I have had the thing run for 30 minutes with no problems, and yet sometimes it will give out in five seconds!
It is giving all the appearences of a receive failure, and resetting the RC is the only thing that can make it recover. I have tried 2 different camera boards, with and without the TTL converter (made a special cable for without!). I have tried software and hardware resetting the camera board, to no avail. (It resets the camera board, but the RC never seems to receive anything, including the power-on ACKs, after the failure). Can anyone help me on this? It is frustrating me to no end. When I say random, I mean random! ![]() EDIT: I wonder if this will clear up the problem? It looks as if maybe we are setting the RX overflow bit now and them (maybe due to a coincidental firing of a lot of interrupts in a short period of time), and this will halt the RX completely until the following code is called. Kevin, could you please help me with this? I haven't worked directly with the PIC USARTs before. ![]() Code:
if(RCSTA2bits.OERR)
RCSTA2bits.CREN = 0; // Make sure the receive is still enabled!
RCSTA2bits.CREN = 1;
RXINTE2 = 1;
Re: Camera glitch / failure
Code:
// if the interrupt handler was disabled while data was being received,
// data may have backed-up in the receiver circuitry, causing an overrun
// condition. So let's check the OERR bit to see if this has happened
// and if it has, we'll need to reset the serial port receiver circuitry
// to get data flowing again.
if(RCSTA1bits.OERR)
// reset by turning off the receiver circuitry, then...
RCSTA1bits.CREN = 0;
// ...turn it back on
RCSTA1bits.CREN = 1;
// indicate that we've had an error
RX_1_Overrun_Errors++;
-Kevin |
OK, thanks. That worked just great!
![]() It is maddening to waste a few days trying to fix an error that can be fixed by flipping one bit. ![]() |
| CMU Camera kills robot controller if not found. | Chris_Elston | easyC for FRC | 21 | 03-27-2006 01:30 PM |
| Camera shows no love to drive motors | anifinder | easyC for FRC | 4 | 02-13-2006 09:31 AM |
| How To Use the Google Camera | generalbrando | Kit & Additional Hardware | 2 | 02-07-2006 03:00 PM |
| Camera Is Spazzing Out! | BrittanyV | Programming | 15 | 02-04-2006 12:39 PM |
| Scripting Setup and the Camera + Serial Port Drivers | CJO | Programming | 22 | 01-11-2006 04:42 PM |
