Go to Post Team spirit is not all about the tools/noise makers. The Tigertrons didn't have any sort of noise makers. Consider other aspects of the award by making signs, mascots, cheers, and how you interact with other teams. - team222badbrad [more]
Unread 02-21-2006, 02:01 PM
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
Innovations in Control
So, now that it's crated and shipped, what sort of cool new control systems have you guys developed?
Team 888:
2 Drivers-1 for picking up balls, 1 for shooting
Each driver has a customized handling configuration. Our ball-picker-upper driver has full speed, direct control of the motors with joysticks. Our shooter driver (me) has controls that improve small adjustments by controlling the rate of turning with a gyro instead of mapping joysticks to the drive motors.
Our feedback system includes voice recognition and synthesis to improve computer-to-driver interaction and a camera-view HUD (Heads Up Display).
The shooter-driver system also allows the driver use body position and range calculations to set the speed of our shooter without gyro or accelerometer sensors on the robot.
Sensor feedback on the robot will allow the bin system to detect the location of the balls and move them into position for firing. It can also detect if balls are getting jammed in the bin and can automatically activate the unjammer.
Please contact Team 888 or stop by our pit at Pittsburg, Annapolis, and Nationals.
Unread 02-21-2006, 02:07 PM
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Innovations in Control
The camera-view HUD, is that sending video? If it is, that's not legal.
We have a fully automatic ranging and targeting system; I rewrote the camera handlers to speed everything up drastically.
We had an automated ball-finding vision system, but I couldn't use it because auto mode is so short
I wrote a dashboard that displays a lot of information on the status of the autonomous systems on the robot, and is incorporated into our control panel.
The second driver's job at this point is to babysit the automation, and take over in case of catastrophic failure.
Sine we have dual shooters, they are staggered in software using switches on the firing paddles.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 02-21-2006, 02:33 PM
Billfred's Avatar
Billfred Billfred is offline
Well this is something different...
AKA: @WmLeverette, @GarnetSq, @SCRIW...
FRC #4901 (Garnet Squadron); FRC #0000 (AndyMark)
1293 is sticking with the tried-and-true two-drivers, two-joysticks technique. It works for us.
Then again, this year we are improving on our controls method in other areas. How so? All will be revealed in due time...
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Facebook-er
Billfred's World Tour: USC KO Palmetto CMP Robot Rodeo MHT KO Florida Palmetto CMP Capital Clash USC Kickoff FVC Orangeburg Florida Peachtree Palmetto CMP Mission Mayhem 1902 Vex Event Duel on the Del. CalGames USC KO Florida Chesapeake Palmetto CMP BattleCry Mission Mayhem Bruns. Eruption Clem. KO Chesapeake Palmetto CMP IRI TNT G'Ville Tech Scrim. Bayou Palmetto CMP IRI GRITS TNT Bayou Palmetto CMP IRI Citadel KO Peachtree Palmetto CMP IRI TNT SCRIW Citadel KO Peachtree Palmetto CMP IRI SCRIW II Chapin KO Palmetto South Florida IRI SCRIW III Chapin Kickoff SC FTC CMP Palmetto SC FLL CMP Orlando CMP Midknight Mayhem SCRIW IV USC Kickoff SC FTC CMP Palmetto Orlando CMP IRI THOR SCRIW V Chapin Kickoff SC FTC CMP Palmetto Orlando UNC Asheville CMP SCRIW VI (57,934.5 miles, and still on a mission from Bob)
Unread 02-21-2006, 03:10 PM
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
our 2 axis shooter gimbal is aimed autonomously using the CMU cam. The manipulator driver just presses the fire button. Of course, there is manual override.
1139 Alumni
Unread 02-21-2006, 04:20 PM
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
2 drivers, 3 joysticks, and a random glowing red button which when put sunglasses over, prompts freshmen to sing "rudolph the red nosed reindeer".
Don't ask.
As for the bot, you'll have to wait till the vid or pic is released to see.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 02-21-2006, 05:12 PM
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
2 drivers 4 joysticks . .
stick 1: tank left(trigger halfs the speed for fine control)
stick 2: tank right(triger halfs the speed for fine controll)
stick 3: opperates the turret(triger does an auto lock, x axis allows for the operator to controll manualy, hat allows for manual controll of the camera)
stick 4: opperates the cannon(triger fires, thumb sets the speed to what the code tells you the speed should be at your distance, aux 1 turns the speed down, aux 2 turns the speed up, and when you take the y axis all the way to 0 it turns the canon off.)
the dashboard shows the speeds of the 2 drive moters(well pwm value really) weather the camera can see the target, weather the turret is locked, what the speed of the cannon i if your on offence or defence
while it seams complicated its actuly very intuitive . . most things on there are for manual overrides
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 02-21-2006, 05:18 PM
coldabert's Avatar
The Dude
No the camera view is not sending any extra video other than the data that is transmitted over the serial port and through the dashboard
Unread 02-21-2006, 05:26 PM
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Succesful goal tracking and scoring in Auto mode.
Custom PCB for LCD Display Panel and Vocal feedback to the subsystems operator.
Our OI Talks
Cool beans
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 02-21-2006, 05:33 PM
Stuart's Avatar
#include coffee.h
ohh forgot the coolest thing . . during auto mode our dashboard shows a "startup sequence" eather the "Evangelion" active links start, or the "Big-O" ye not guilty start . . depending on the auto mode/mood we are in.
Unread 02-21-2006, 06:30 PM
coldabert's Avatar
The Dude
Our OI Talks
Cool beans
What sort of stuff do you have on the PCB? and is your vocal feedback software based or a record playing chip?
Unread 02-21-2006, 07:27 PM
Sachiel7's Avatar
AKA: Shayne Helms
Our PCB is more of a mainboard that hosts a 4x20 LCD panel and the Emic Text to Speech Module, being run off a BS2 microcontroller.
http://www.parallax.com/detail.asp?product_id=30006
And I've attached a snapshot of our PCB.
-=Sachiel7=-
Unread 02-21-2006, 07:40 PM
Joe J.'s Avatar
Joe J. Joe J. is offline
My Gaming Is FIRST!
AKA: Joey
FRC #0862 (Lightning Robotics)
Team Role: Coach
Joe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond repute
Send a message via AIM to Joe J.
862 will have two drivers using two unmodified PS2 controllers, of course those are hooked up to our PS2 / OI Adapter
Driver has control of the tank steering and the ball intake and output functions
Copiolet has control of the shooter and the feeders to and from the shooter, as well as the auto aim
Check it out at Great Lakes , Wisconsin, and the Championship
Joe Jagadics
Lead Mentor / Coach
Lightning Robotics FRC Team 862
Unread 02-21-2006, 08:27 PM
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
2 drivers, one drives, the other shoots and runs the rollers to pick up balls
We have a two stick drive.
A laptop with a dashboard program that shows us how fast the launch wheel is spinning, our battery voltage, the gear we are in (displayed by an 8-bit rabbit and an 8-bit turtle), and a crosshair so the camera doesn't have to do all of the aiming.
Unread 02-22-2006, 08:17 AM
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Cuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond repute
Send a message via AIM to Cuog
Our team doesn't have very much in the way of driver inovations just a dual tank style joystick drive for the primary and a custom switchblock for the secondary driver to power the roller, "jock strap" and "Drop it Like its Hot" systems
KK4KQO
http://voltair.us
Too many projects, too little time.
  #15   Spotlight this post!
Unread 03-02-2006, 03:18 PM
coldabert's Avatar
The Dude
Sounds like alot of teams are trying out new techniques with their control systems. Good luck to all and I hope you can get 2nd place at nationals (cause team 888 and our partners are obviously gonna pwn).
Concept of PID explained ConKbot of Doom Technical Discussion 11 01-26-2008 11:11 PM
Pre-manufactured control box for FIRST Ben.V.293 Technical Discussion 19 08-22-2005 11:53 AM
2005 RadioShack Innovation In Control Award--What Won? Billfred Control System 8 06-12-2005 12:51 AM
2005 RadioShack® Innovation in Control Award! dez250 General Forum 10 03-10-2005 08:29 PM
What do you wish you knew about the new control system? Joe Ross Control System 2 01-09-2004 08:47 PM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
