If any of you are watching the webcast, 1 alliance was just disqualified. I didn't exactly catch why they were disqualified, can someone post the reason here?
Thank You, Tomasz Bania |
Re: VCU DISQUALIFICATION!
They entered the side goal with their robot. Which is a saftey violation (results in a Dq)
ok, thats what I thought I heard, but I didn't think that was a disqualification but rather a disable. Oh well.
Tomasz Bania P.S. That freaks me out as I might be our teams driver and those bumpers easily go under those goals. |
it seems there are a lot of DQ's with robots entering the corner goal. I have one question about this. If our robot puts down a draw bridge to score but it is outside the goal. and then an opposing alliance's robot pushes us from behind therefore shoving our draw bridge into the corner goal. Does that count as breaking the rule as it was non-intentional?
It couldn't have been a DQ for the alliance, because they're back for the 2nd match. It would have to have been a disable. Last edited by Nuttyman54 : 03-04-2006 at 12:40 PM. |
No it was a dq. the elimnations are best out of 3. So if you get dq one match you can still play the others.
Ahh, sorry, i had a different conception of DQ. In this case it just means a 0 score for the match?
Yeah. A dq is just for the match.
It's not a safety violation, the rule is G21:
SF 1.1 resulted in a DQ for the red alliance due to incursion in the corner goal during autonomous mode. Was that the correct call? Without seeing what exactly happened, I know its difficult to say, but no where in the rules or Q/A is it stated what happens during autonomous incursion. Typically there is a grace period or some sort of minor penalty and temporary disablement if a team breaks a rule during autonomous and not a DQ. Any idea?
Kev |
#11
In our first match at the Pacific Regional, we got pushed by another robot into a corner box while trying to dump balls in and got a 5 point penalty, but not a DQ. This was not in autonomous mode.
#12
Actually, I had asked once in the Q/A about incursion into the goal more than 3in... and they said that was a DQ. Didn't give any exceptions for being pushed, etc, which implies that your robot should be designed not to go in more than 3in period. That is a safety violation whether you did it or got pushed.
http://forums.usfirst.org/showthread...ight=incursion You can bet it's the same in autonomous. Quote:
#13
414 was well into the corner goal (interesting considering I don't beleive their autonomous had done that before), at least an inch past the 3 in "barrier". They have an unfolding flap and drops to release all the balls into the corner goal, so that's how they managed to get that far in.
#14
414 was far enough into the goal that they were over the light panel, which happens to be a more than 3 inches inside the goal. At that point they were potentially interfering with the counting system hence the DQ. Wetzel |
#15
| ATTENTION VCU REGIONAL PARTICIPANTS! | Bytor | Regional Competitions | 0 | 03-30-2004 08:59 AM |
| Serious VCU Fire | Joe Matt | Chit-Chat | 3 | 03-26-2004 06:04 PM |
| VCU COMPETITION STATUS | ggoldman | Regional Competitions | 98 | 03-07-2004 05:54 PM |
| Can any VCU teams help me?/ VCU thanx | DUCKIE | Thanks and/or Congrats | 0 | 03-13-2002 09:17 AM |
| Numbers at VCU | Madison | Regional Competitions | 5 | 03-10-2002 01:26 AM |
