Go to Post Maybe my brain fog factor has expanded after wading through 1114's competition data sheet, so I cannot see the forest for the trees. - Bill_B [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Cross the Road Electronics
ADVERTISEMENT
Unread 03-17-2006, 02:41 PM
kjhobin's Avatar
kjhobin kjhobin is offline
An Info Sys Student at Drexel
AKA: Keith Hobin
FRC #0555 (Montclair Robotics)
kjhobin is a jewel in the roughkjhobin is a jewel in the roughkjhobin is a jewel in the rough
Send a message via AIM to kjhobin Send a message via Skype™ to kjhobin
Help! making an inventor file into an autodesk file
Hey everyone,
Does anyone know how to make an inventor file into and auto desk file? Ultimately in the end, we need a .DXF file to use a computerized plasma cutter.
Thanks in advance!
-Keith
Montclair Robotics FIRST Team 555 Alumni
FIRST Volenteer
Unread 03-17-2006, 03:37 PM
JagWire's Avatar
JagWire JagWire is offline
Team 1742 College Mentor
AKA: Tim Long
FRC #1742 (Shockwave)
JagWire has a spectacular aura aboutJagWire has a spectacular aura about
Send a message via AIM to JagWire
Re: Help! making an inventor file into an autodesk file
Originally Posted by kjhobin
Hey everyone,
Thanks in advance!
-Keith
Well, since Inventor doesn't have an export or save as option to .DXF, probably the easiest way is to import the file into another CAD program that does support .DXF. I no longer have an active license of AutoCad, so I don't know if it will do it or not. But, I do have access to a CAM program called BobCad that will save as a .DXF. So I'm sure that it can be done. Sorry I couldn't help more... stupid one year licenses on software... expired about two weeks ago...
~Tim~
Team 1742: Shockwave
2006 Robot "Sprocket"
2007 Robot "Rampzilla"
2008 Robot "Trigonosaurus"
Aut viam inveniam aut faciam.
I'll either find a way or make one.
www.team1742.com
Unread 03-17-2006, 09:35 PM
CraigHickman
Posts: n/a
Actually, Inventor DOES have an option to export to dxf.
Make a drawing of the part, single view per page. Then delete the ansi box, and side grid. You can then go to save copy as, and choose dxf format. Inventor has a nice little feature that it will export directly into a .zip file.
Unread 03-18-2006, 08:57 AM
kjhobin's Avatar
AKA: Keith Hobin
Thank you! im going to try this!
FIRST Volenteer
Unread 03-18-2006, 09:59 AM
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Yeah, this is really quite nice. Just put your part in an idw. , then save as- dxf, dwg, dwf, etc. Actually, the first time you use it, you can select all the little options like saving or ommiting the drawing box, annotation, zipping, etc.
The only thing I don't like about the idw. is that you cannot save it in .jpg. You can save into .bmp, but it's quality isn't good enough to print it seems.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 03-19-2006, 10:04 PM
JagWire's Avatar
AKA: Tim Long
doh! ok, then i'm gypped, for some strange reason the Inventor Pro 10 copy I've got installed on my comp. doesn't have that nice little .dxf option... and here I just assumed they were all that way! well, you learn something new every day!
www.team1742.com
**FIRST EMAIL**/Update on the Autodesk Visualization Award – Online Voting Instructi KathieK FIRST E-Mail Blast Archive 0 02-23-2006 03:42 PM
heres the code. y this not working omega Programming 16 03-31-2004 02:18 PM
The Autodesk Design Awards 2003 – Call for Entries Brandon Martus 3D Animation and Competition 1 12-26-2003 05:40 PM
File Sharing and Revision Tracking Madison freelanceFIRST 14 06-04-2003 05:01 PM
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 01-22-2002 10:06 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
