Go to Post Who cares about having a boyfriend when I have my robot? - Jaine Perotti [more]
Go Back   Chief Delphi > Technical > intelitek easyC/REC information > easyC v2 for Vex
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 04-15-2006, 05:49 PM
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
None #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Send a message via AIM to Chris_Elston Send a message via Yahoo to Chris_Elston
Make our own VEX programming cable?
Has anyone just tried to make your own VEX programming cable? We would like to have an additional one around. Does anyone know any information like a pin out?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 04-17-2006, 08:13 PM
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Re: Make our own VEX programming cable?
Why? You can buy them from Radioshack for $50.00 now. You could also check
aat vexlabs. I think they have them for less.
Unread 04-17-2006, 08:23 PM
Controls Engineer
AKA: chakorules
No programming kits within MILES of our location or online. I snagged one on eBay however. I'll just have the kids ohm this cable out and we can make another for a spare.
Favorite CD quote:
Unread 04-17-2006, 09:38 PM
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
It's not simple to duplicate the programming modual. It's a usb to serial cable and that little orange box. In that box is a microcontroller that handles the programming. Not an easy thing to clone.
Unread 04-17-2006, 10:19 PM
Controls Engineer
AKA: chakorules
It's doesn't HAVE TO BE a USB to Serial cable does it? Our Dell D810 has a real serial port on it.
I know all about USB to Serial converters. I have my own design. I use a FTDI USB serial chip to handle the RS-232.
Other cables for reference...
http://www.plccables.com
bottom line, no problems.
I am using the FTD FT232BM chips.
http://www.ftdichip.com/Products/FT232BM.htm
Favorite CD quote:
Unread 04-17-2006, 11:02 PM
FRC #1640
You can use another usb cable as long as you use the right driver. I believe others have used a serial cable. That's not the problem. It's the code on the pic inside the little orange box.
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 04-25-2008 08:11 AM
vex programming arcade drive setting MikeL303 FIRST Tech Challenge 3 10-17-2005 08:26 PM
White Paper Discuss: VEX / intelitek easyC programming document dez250 Extra Discussion 3 09-15-2005 02:20 PM
Vex Programming foobert FIRST Tech Challenge 3 06-24-2005 12:09 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
