Go to Post There is no shame in admitting someone is better than you at something doesn't make them a better person just means they have skill you haven't figured out yet. The only shame is if you are too proud to ask for help and to learn. - Mc Kenna [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
GODUC
ADVERTISEMENT
Unread 06-14-2006, 05:46 PM
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
(Off Season) Blinking LED Problems
I am having a problem with some LED's that I am using for a backlight (they draw less power for my project). The LED's are powered by a 5V regulator then into a 10 ohm resistor then paralleled together with a common ground. The LED's work fine for about seven hours then they begin to blink (fail). Any ideas or solutions?
Eat, Sleep, Build Robots
Unread 06-14-2006, 06:10 PM
DonRotolo's Avatar
Is wishing HE had summers off...
FRC #1676 (Pascack PI Oneers)
Re: (Off Season) Blinking LED Problems
What color light are the LEDs? That's important.
As a first guess, even if they are white or blue, your 10 Ohm resistor is not enough. You are overpowering the LEDs, causing them to fail.
Asuming 3.5 volt operating voltage at 20 mA, you need to drop (5.0 - 3.5 = 1.5) volts. To do that, R = V/I = 1.5 / 0.020 = 75 Ohms. I'd use the next size larger, for just under 20 mA. You can re-do the calculations with the manufacturer's specs (voltage, current) for the LEDs you're using. (Or just go to the Panasonic site and find something equivalent).
Don
Unread 06-15-2006, 12:08 AM
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
What is the regulator powered by? you may wish to hook a multimeter to the LED leads and see if it is the LEDs which are doing this or if it is your power supply ( the regulator needs a heat sink?).
-Mike
Unread 06-15-2006, 06:35 AM
Unsung FIRST Hero
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Rookie Year: 1996
Alex,
A little more info please...Is the 5 volt regulator getting hot to the touch? Can it survive the 5 second rule? (can you hold your finger on it for five seconds?) Typical 7805 type regulators have thermal and over current protection which cause them to shutdown or scale back on current under certain conditions. How many LEDs are you trying to power? Also, as Don has pointed out above, the resistor may be sized wrong. I like to use the rule of thumb of 2 volts drop across a standard LED and a 20 ma forward current for calculating the series resistor for one LED. Under these conditions, a 150 ohm resistor is the calculation. Standard values of 120 or 180 should work fine. If you are paralleling all the LEDs than you need to modify the resistor for the parallel current. If you are using a super brite white or blue LED these may have up to 4 volts forward drop and the calculation needs to be modified for those particular devices. Know the beast you are dealing with.
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
Unread 06-15-2006, 07:25 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Putting LEDs in parallel is rarely a good idea. Any slight discrepancy in voltage drop among them will cause the current to go primarily through the one with the lowest voltage, and a shared current limiting resistor will not have the desired effect.
How many LEDs are you using, and what voltages are available to you? Put as many in series as you can, and use multiple sets of series-connected LEDs each with its own resistor.
Unread 06-15-2006, 11:53 AM
Alex698's Avatar
Sparky
Thanks to everyone for all the help, I will try the series circuit and the higher ohm resistor (in different trials). Thanks!
PBASIC operator interface LED problems John Gutmann Programming 1 05-19-2005 09:39 AM
Off-Season Orlando Stephen Kowski Off-Season Events 2 04-01-2004 08:15 PM
'Program State' LED stays blinking yellow after download clynch IFI Control System 5 02-18-2004 06:34 PM
Off-Season in Richmond?! Sachiel7 Off-Season Events 17 11-24-2003 11:17 PM
OFF SEASON COMPETITIONS IN NY? DaBruteForceGuy Off-Season Events 24 06-14-2002 01:40 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
