USB Chicklet
Is it possible to use more than one controller when using the USB Chicklet? If so do you need two USB Chicklets or can you use a splitter to separate the one USB port?
Re: USB Chicklet
and specifically: Re: USB Joystick adapter is here! Quote: Originally Posted by Michael Hill View Post Is it possible to run multiple joysticks through a USB hub using only one unit? The Chicklet only supports HID. It does not support HUB. We have a solution that does support HUB and other device classes however that solution was not cost effective. We wanted to keep the device affordable for FIRST Teams. Also the 15-pin joystick port does not provide enough interface to support more than one device. We have a device that outputs RS232 data instead of analog/digital. It is less expensive than the chicklet. If we had a serial port on the O/I this would have been the way to go. Mike Copioli CTRE team 217 |
does anyone know how to attach power to the usb-chicklet? i can't seem to find any clear instructions on powering the chicklet and i dont want to risk it with wiring it up wrong (backwards).
Re: USB Chicklet
The Chicklet has protection against reversing its polarity so don't worry about that. The connector that is supplied with the chicklet comes apart buy unscrewing the metal plug from the plastic housing. The Chicklet needs a center positive to function. So solder the positive lead of a backup battery to the center terminal of the plug. The negative(black lead) goes to the outer terminal. Or while practicing you can use a 9 VDC (center positive)unregulated power supply. |
Re: USB Chicklet
hey does anyone know how to code the chicklet?
does anyone know anything about the header pins on the chicklet. What do we use them for?
Re: USB Chicklet
The Chicklet does not require programming. It can be configured and calibrated which is what pins 1 and 2 on the header pins are for. Please read the user manual for more information:
http://www.ifirobotics.com/docs/usbc...ual-rev1-1.pdf |
Re: USB Chicklet
The OI has a radio modem port that is not used during competition. Is it a functioning serial port, or simply a hardwired deal that cannot be interfaced to run data into the competition port's data out? |
Re: USB Chicklet
Actually the radio modem is used in competition. It is how the O/I communicates with the R/C. I think you mean the dashboard port, which provides output only. |
#10
Re: USB Chicklet
has anyone tried mounting the chicklet in a project enclosure it so what size enclosure did you use and what did you you cut for access to the ports
#11
Re: USB Chicklet
One warning about the Chicklet:
Using the original X-Box controller. We had two. One made in China, and one made in Malaysia. The chicklet said that the one made in China was not supported, while the one made in Malaysia was. Just chance I brought two with me. Anyway, It works. Jacob |
#12
Re: USB Chicklet
| How the heck do you use an XBOX360 controller with the chicklet?? | waialua359 | USB Chicklet | 58 | 02-17-2008 11:43 AM |
| chicklet USB/xbox 360 controller | spsteam1512 | USB Chicklet | 1 | 01-10-2007 10:14 PM |
| USB I/O | CJO | IFI Control System | 2 | 10-15-2005 07:17 PM |
| usb to db15 | 663.keith | Technical Discussion | 21 | 01-20-2005 02:16 PM |
| USB to Serial | Jack | Programming | 24 | 12-23-2002 01:21 PM |
