pic: mounted Anderson
Re: pic: mounted Anderson
You sure its okay with FIRST that you screw things into the battery plastic?
I love the way it just clicks in, but I would have used epoxy or some other kind of adhesive instead. (It seems screwed to the battery to me.) |
If that's attached to the battery, it's illegal per <R65>.
The Good:
The Anderson quick disconnect was not tampered with in any way possible. The quick disconnect housing has 2 holes in the center of it already. Since they did not drill, machine, or otherwise into that part, it would be legal and I've seen this done hundreds of times with many teams before with no problems. The Bad: I do agree some more needs to be done to hold the battery down though. Maybe a velcro strap, or something. Anything. Last edited by Elgin Clock : 01-17-2007 at 12:12 AM. |
And yes, I do realize that drilling through that thin flange probably won't be a hazard. But the slightly increased possibility of a stress fracture or some other gruesome fate precludes that sort of modification, no matter the location. I don't think FIRST will look fondly upon this modification, but go ahead and ask the Q&A for permission (describing specifically why this is a safe modification in your opinion), because I know you don't want to have to buy new batteries to replace the modified ones. Last edited by Tristan Lall : 01-17-2007 at 12:23 AM. |
I don't know for certain, but that metal bracket could just be glued on. 842 has attached handles to their batteries for a couple of years now (pretty sure they're glued), and I don't believe they've had problems passing inspection anywhere before.
Gluing components to the battery is not allowed per <R65>. Similar rules have disallowed this in previous years also. |
![]() *Remember the old joke about drilling holes in the battery (to lighten it, back in the days when the battery counted toward the robot's weight)? |
Meh. I guess it's a good thing I'm not an inspector then, cause I would let that go. |
#10
In this instance, stress transferred to the battery case through the drilled handle (e.g., due to shock loads when the robot hits something, or by installing a new battery in a hurry) may be outside of the limits considered by the battery's manufacturer when they designed the case. So my opinion is that <R65> makes sense as applied to this situation. But really my opinion about the rule doesn't matter; the rule is there and as an inspector I have to note the violation, and require the team to correct it before their robot can pass inspection. |
#11
Do we all have small hands or something? I can pick up the battery with no problem just as it comes. If you can't use both hands. If you don't have two hands free, grab a team mate. It is a probably a good idea to assign one person to be in charge of the batteries anyhow.
#13
Hey, at least they find out NOW that it's not allowed, rather than at inspection.
Telling them is GP. Don |
#15
welll i couldnt find a pic of our last year rock and roll robot but we did have the battery right in the front it was protected we had the anderson connector coming aLl the way from the backk to the front and we did screw it onto the frame so it just clicks in as shown we had no problem with it and no problems given from the judges
| How is your camera mounted? | bear24rw | Programming | 19 | 03-16-2006 11:36 AM |
| pic: 1559 Turret mounted | bradleym1559 | Robot Showcase | 2 | 02-04-2006 08:14 AM |
| Backwards Mounted Motors | Mike | Programming | 11 | 06-22-2005 03:21 PM |
| Electronics mounted on metal | Nitroxextreme | IFI Control System | 3 | 02-01-2005 09:42 PM |
| Can the Cameras be mounted Sideways? | vicecityman666 | Technical Discussion | 1 | 01-29-2005 09:21 AM |
