Turn off outlining?
I just updated to Inventor 11, I was using 10 because our FIRSTbase registration was all messed up. So when I open my robot assembly, all of the parts are outlined in white (all the edges). Is there a way to turn this off? It just looks bad and hurts my eyes...
Thanks Last edited by Madison : 01-17-2007 at 12:43 AM. |
Re: Turn off outlining?
On the top bar near the right is a group of buttons: perspective/orthogonal, shadows, and one for wireframe/solid. its just to the left of the material selection drop down box. Check that to make sure you don't have the middle solid plus wireframe selection selected.
I tried that - everything is normal. When you zoom in it looks ok - every edge is just white. With fairly complex parts with a lot of edges (like the AM wheels), when zoomed out, it just looks like a big clump of white lines...
Tools>Application Options>Display - unckeck edge display. But something doesn't sound right as the usual edge display is black not white so I'm not sure exactly what you are seeing unless someone has been fooling around with the defaults. There is a color swatch selection next to the checkbox for edge display.
[quote=JD Mather;558754the usual edge display is black not white[/QUOTE]I'm pretty sure it all depends on the material the part is made out of.
I haven't really noticed this in assemblies yet. Maybe that's because I got used to seeing it in the individual parts before I went for assemblies. Fortunately, they aren't there when you render . |
Nope. Try it. Default is black.
Strange, I've always seen white edges.
Next to the Edge Display option in Application Options, there are another check box and a color box. If the check box is checked, edges are shown in the color chosen in the color box. By default, the color box is black. If the check box is unchecked, the edges are shown in white. So white is default, and black is default when edges are colored. If you've ever wanted to know how you can get pink edges...there you go. ![]() |
Depends on the Color Scheme you use. Tools>Application Options>Colors tab - try changing color scheme to Sky or Presentation. The edge display color will change. If you checkmark the box on the Display tab the default is black.
#10
Interesting. I made a part, and by changing the part material on the dropdown, it changed the outline color.
#11
I have been having the same problem with drawing the 6" traction wheels from andymark. It still has some work but this will definitely speed up the process.
| Anyone know how fast the Solenoids on the MINI RC can turn on and off? | Generalx5 | IFI Control System | 1 | 01-06-2007 06:39 AM |
| does the turn on/off swicht have to be assessable | FlyingDutchman | Electrical | 10 | 02-05-2006 03:45 PM |
| Can I turn off the touchpad on my laptop? (Dell Inspiron 8100) | Elgin Clock | Technical Discussion | 8 | 07-03-2004 12:59 PM |
| hanging off off other robots that are hanging off the horiz bar | Andrew Dahl | Rules/Strategy | 15 | 01-12-2004 06:14 PM |
| solution to off-topic turn of thread 'its all about the money' | mike o'leary | Rumor Mill | 54 | 07-31-2001 09:03 PM |
