Highest Score Possible
whats the most amount points you can score total, saying all your tubes were used.You do not have enough tubes to cover the entire rack, you are short by 3, so what would it be, and how would you do it?
pretend noone uses spoilers just answer to save me the 15 minutes of guess and check work |
Re: Highest Score Possible
596. 656 with bots.
Each team has 21 Tubes (9 tubes on the field, 9 in home zone, 3 for autonomous)
There are 24 spots on the rack - - 0 0 0 0 0 - 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 you have a total of 3 x Rows/Columns of Two = 3 * 2^2 =3 * 4 = 12 5 x Rows/Columns of Three = 5*2^3= 5*8 = 40 1 x Rows/Columns of Five = 1 * 2^5 = 32 2 x Rows/Columns of Eight = 2 * 2^8 = 2 * 256 = 512 Bonuses 2 x Robots Lifted 12" = 2 * 30 = 60 (this is assuming you do not have an unpowered anti gravity machine for the 3rd bot) Grand Total = 12 + 32 + 40 + 512 + 60 = 656 points! Hope that helps! *Edit ..miscounted tubes originally...fixed now !! * Last edited by ggoldman : 01-19-2007 at 02:40 PM. |
o ok thanks guys
and ricksta, see you in manchester Last edited by Dantvman27 : 01-19-2007 at 12:09 PM. |
3 rows of two--3*4=12 5 rows of 3--5*8=40 1 row of 5--1*32=32 2 rows of 8--2*256=512 Total rack: 596 Add 60 points for lifting 2 robots: 656. Right numbers, wrong values. The correct score for the pattern listed (with the 5 rows of 2) is: 664. Now, will anyone get 656? Yeah, right. |
remember the 3 ringers in atonomus. you could potentialy cover the whole rack
They were already included.
Thanks for the correction.
I initially miscounted the number of tubes available (and therefore forgot to clean-up the mess from b4.) The inital post with the math is now corrected to relect the CORRECT solution. |
| Highest Score? | EricH | FIRST Lego League | 17 | 12-11-2006 11:24 PM |
| Highest Losing Score | Ben Piecuch | General Forum | 9 | 04-03-2005 10:17 PM |
| highest COMBINED score | mentorn | General Forum | 15 | 03-28-2004 07:05 PM |
| Highest Score Record Broken | Jonathan M. | General Forum | 1 | 03-25-2003 08:30 AM |
| HIGHEST SCORE | archiver | 2001 | 2 | 06-24-2002 01:17 AM |
